fiberglass box build in an 07 tacoma access cab
you should try using a finer grit sand paper soo you dont get those scratch marks...
are you using 40 grit?
"yes... it will play like that all day!"
im sure its just to knock down the big stuff then hell switch to finer grit once he gets to finishing
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Yea it's 40 grit. And I was just using it to knock it down. After the glazing putty I will go over the whole box and get down to 400 eventually.
I finished with the filler and got it sanded down. Then I marked out all the spots where there were pin holes or deep scratches and spread some glazing putty on. Unfortunately, the putty didn't dry and I will have to wait until tomorrow to sand it and paint the box. If everything goes right tomorrow I should be able to finish painting the box, install it and build the trim panels and wire everything up and test it.
I don't have time to get the box smooth enough for real paint so it is going to be in primer for a while since I'm leaving for Florida tomorrow and will be gone a few months. I painted the port and corners so when the trim panels are put on if there are any gaps you wont see bare wood. I know it looks sloppy, but I'm not worried about it. It's not done. Give me crap if you want but I'm NOT done.
Yea the pictures suck, lighting was horrible. And before anyone says anything, I know it needs more body work. That's why I didn't paint it because I don't have time to do it. That is also why I didn't spend much time making the paint on the port look good.
