DC Sound Lab
Should take it like a champ n beg for more
2005 Lariat F-150
On 30 inch DUBS
6 Crossfire XS-V2 18's
2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4
12 - 6.5 Crescendo mids and 4 Crescendo supertweets
SMD 340 alt, Mechman 270 alt
7 NSB 170 batterys
^2x
And thats all you want to put to it. I am looking to put a DC 3500 on my 3 Level 3 10" DC subs wired at .6667 ohm and do it for daily. and tuned to 45 htz.
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
^2x
i eventually want two of the AQ3500D.1s and strap em to two lvl 5 18s
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
it will handle fine *in the proper box and electrical system...they will run fine on that power and want more unless its clipped you will fry that sub...i ran my level 5s on that same amp at .7 ohm daily each and they loved it
NoFearX18 said:
well i have a 300 amp iraggi alt 2 D3400s under the hood and 2 D3100s in the back big three in 1/0 and will have a vcm next week and will have a second alt going in as soon as soon as i can do that
i have a TPI scope plus 440 on the way right now so i will be able to set my gains correctly
how did they like the .7 ohm daily?
and what electrical did you have behind it?
go with the xl it will sound better on that power
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
you got plenty of power then...ill say this...right now there at .5 daily and there perfectly fine...and i run mine on 1 DC Power 350xp alt and 4 D1400s big 3 blah blah blah haha
NoFearX18 said:
Yea I've seen abunch of people runnin em under one ohm with no problems
I wanna get 1 3500d to run my 4 l7 15s til I get some dc audio in there
  • 3 weeks later...
wanted to bump this cause i have my burban stripped and im not installing anything again till i get a new amp but im ready to decide on a new sub set up
im set on a AQ3500D.1 and it will run my 4 L7 15s at 1 ohm till i get a DC Lvl 5 18" (eventually will be two lvl 5 18" on two 3500Ds strapped)
what i wanna know is what is a good box size after sub-port and bracing displacement for that power?? daily tuned around 32-34Hz
and how much port area for that 1 lvl 5 18"
its gunna be 1 18" in the back of a suburban for now so i have PLENTY of room to play with
thanks for any help :drinks:
  • Who's Online   0 Members, 0 Anonymous, 3902 Guests (See full list)
