side by side t-line
baaudio
considering teh channel should be narrower at the vent end than the driver end the enclosure might be a bit off...this is why we typically fold them around the back, sso the narrow channel is behind the main channel and the vent is above the driver (or below if the driver is on the bottom)
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
that is a different type of enclosure
its tapered and is like a horn. a straight transmission line is a very simple design that is very effective
now idealy you want the sub and port facing the same direction (combines front and rear waves) but if this is all you can do then it should still be fine
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 1676 Guests (See full list)
