interesting. now finisht it up
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
interesting ... :popcorn:
probably guna be finished this week. Wondering how to cut a hole in the deck, possibly a cutting wheel? how big should i make the hole? the same size as the port or bigger/smaller
any ideas? thanks
make it the same size of the inside of the port opening. that way you can drill a couple of holes in your rear deck and screw into the port. you say theres no room but you should be able to get some screws in it from the inside of the car. your port has to be longer also so it will butt up against the rear deck then you can seal it to the rear deck
2015 silverado crew cab
nothing atm but soon...
yea there will probably room to screw some screws in but the deck is nota flat surface and i cant make it any longer without making the port larger on one side and smaller on the other side. I wont be able to seal it off but this way most of the air will go directly into the cabin
If you just extended the port into the rear deck and kept it the same opening dimensions, you would lower the tuning. I read through it, and I don't think anyone answered that question.
yep thanks, i kept all the dimensions the same and raised it 2.75 inches and its tuned to my liking now. Just wondering how i should cut the square into the deck
