Dan2427 Posted December 17, 2010 Report Posted December 17, 2010 So I bought two level 5 18s that are dual 2 ohm which will be perfect for when I get my other 3500 so I can hook up them up at 1 ohm to each amp. Can I wire them up each at 1 ohm now then go to each of the terminals since the amp has 4 terminals or will that still bring it to a .5 ohm load in the end anyway? Let me know if I need to explain better. Thanks, Dan. 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
bassl0va Posted December 18, 2010 Report Posted December 18, 2010 Yes, those terminals will be internally connected so you can wire them like that to get 0.5 ohms. I'm probably going to get flamed again for saying this, but I don't really think you should run it at 0.5 ohms. If you have good electrical and you really want to, you can. My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
TeamHT Posted December 18, 2010 Report Posted December 18, 2010 I wouldn't suggest it either. If you have to ask....I know, cliche but its pretty spot on with your experience. Someone with the proper knowledge and experience wouldn't ask so its safe to assume you don't have the knowledge or experience. Your choice, I run lower ohm loads all the time, but thats one of the reasons I have viagra stiff electrical Tell me...does this smell like chloroform to you?
Dan2427 Posted December 18, 2010 Author Report Posted December 18, 2010 No I dont want to run at .5 ohm I want to run at 1 ohm but my woofers wont allow that. I know these subs will be perfect when I get my second amp. I'm running at half ohm now with my 15 and drop to no lower then 13.2 full tilt if I keep the rpms around 2000 like if I'm driving or just reving it up. at idle ill go into the mid to low 12's if I play it for like 30 seconds or more. thanks for the help guys. 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
