ChevyBoy95 Posted December 26, 2010 Report Posted December 26, 2010 I have the ks60.2s and am having a dilemma. it seems when my HU (CDE9842) gets over 22 of i think 35 volume, the bass just makes them sound horrible(almost sounds like distortion from bass). I have turned the bass all the way down on my head unit and filtered out anything below around 300Hz(on the amp) and they still sound like s _ _ _. They are 75rms and im running them off of a MB Quart DSC450 aka 50rms to the comp set. They dont see below 13v EVER! I am just wondering if it is the speakers or what. thanks in advance. if it is just the kickers being kickers i might just buy new comps or coaxes. it seems to do it a lot worse when only two of the four channels are running, but i put another set on the other two channels and it went to almost no bad bass noise.... Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Sanitarium Posted December 26, 2010 Report Posted December 26, 2010 you've got bass breakout even though your headunit's bass is all the way down and the crossover on your amp is at 300? Can you physically SEE the woofers jumping to the bass by chance?
ChevyBoy95 Posted December 26, 2010 Author Report Posted December 26, 2010 well i was thinking, it only does it when 2 channels are being used it seems. or maybe when the other 6.5s are wired up to the other channels it covers it. but to me it seems like there is almost no "distortion" if all the channels are being used. could it be something like if only 2 of the channels are being used it is pulling power from the other channels? (might sound dumb but i am unsure). ill try and check though. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
StatingROBIN Posted March 2, 2011 Report Posted March 2, 2011 If i were you, i would take some scrap wire and hook up those other two channels so that you dont have any distortion
MrSkippyJ Posted March 2, 2011 Report Posted March 2, 2011 I have the ks60.2s and am having a dilemma. it seems when my HU (CDE9842) gets over 22 of i think 35 volume, the bass just makes them sound horrible(almost sounds like distortion from bass). I have turned the bass all the way down on my head unit and filtered out anything below around 300Hz(on the amp) and they still sound like s _ _ _. They are 75rms and im running them off of a MB Quart DSC450 aka 50rms to the comp set. They dont see below 13v EVER! I am just wondering if it is the speakers or what. thanks in advance. if it is just the kickers being kickers i might just buy new comps or coaxes. it seems to do it a lot worse when only two of the four channels are running, but i put another set on the other two channels and it went to almost no bad bass noise.... sounds to me like a gain issue, but that is just a guess. how is your gain set? also, what do you mean by only 2 channels running? You have it bridged sometimes or you literally unhook 2 of the 4 channels? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
