so i was thinken of putting a 14v battery in the rear of my jeep just for the amp only. would i have to up the voltage just for that battery? the front battery is still a reg 12v battery
Team DBs (Driven By sound)
dude... no... come on lol. you cant charge a 14v battery at 14v and you cant charge a 12v battery at 16v.
12v batts are charged at about 14.4
14 volt batteries are charged at 15.5 or higher.
Where do you think the power is ultimately coming from? The alt ;)
Eclipse cd7000
not trien to ask sumthen dumb. just asken. dunno if i'll have enough cash to by 2 14v batts. just want a constant 14v's at my amp is all
If you want a constant 14v at the battery, maybe you should look into better electrical. You dont use a 14v battery for applications like this (commonly). With a good alt, good batteries, maybe regulator on the alt as well, you'll see a constant 14v at the amp all day every day. No need for a 14v battery unless you can charge it at 16v, which will in return fuck up tyhe 12v up front.
2006 Nissan Z Track.
My Feedback Thread
well i have a adjustable voltage reg set at 14.8cold and 14.4 warm and a 150 amp alt. every one told me not to go past the 14.8 cuz i'd smoke my batteries
Also, wouldn't having batts at 14v and 12v slowly drain each other trying to level themselves out if they are connected to same electrical?
The 14v battery would just go flat. It would sit there trying to push the voltage on the 12v battery up.
A 12v battery is about 2.3v/cell at a good float (13.8) and 1.8vpc when flat (10.8v)
I'm pretty sure these 14v batteries just use 7 cells in series instead of the normal 6 so they'll be completely flat at 12.6v - at which point the 'system' will probably be at a nice equilibrium. Except you would never notice, since the 12v battery would just continue powering your system.... just your alt would always be going flat-out trying to charge the 14v battery up again.
10.x volts fo' life!
so would i smoke the batts if i go to 15.3 cold and 14.8 warm? i'm talken bout the alt temp
What are the batteries again? A quality AGM will be ok with those voltages, IMO.
  • Who's Online   0 Members, 0 Anonymous, 3082 Guests (See full list)
