strapping amps.
lol no i never said more power but if someone only had one 4500 sundown.. and needed another 4500 watt of power.. they just buy another one and strap em for a 2 ohm load at 9000 watts.. thats considered more power than 2 amps seperately at 2 ohms each?? right or wrong?? i know i'm right on this!!!
the total load is 2ohm but each amp still sees the 1ohm load so nothing chages
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
but like i said its pointless to strap 2 amps together.. unless you want better efficiency..
efficiency wouldnt change any look at my above post
I like shiggles then lol
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
true, they still see 1ohm each but efficiency does change. running them strapped lowers efficiency but only by a couple percent.
the benefit of strapping is a little simplicity. you dont have to gain/crossover match. you can use the gain remote that comes with the amp. dont have to split RCAs. its very helpful if you have 2 amps on one sub.
Exactly gain matching is one reason you have a master and a slave. plus you can use a bass knob or bass gain. on my DD amps the gain knob has a clip light so thats a big plus. you can stapp those sundowns lower than 2 ohm i bet with the proper electrical . i have my DDs strapped at .7 so each amp sees .35 and im getting 12k of power out of them. i tried unstrapped lost my gain knob didnt have the overall control i had, and put up same numbers. so strapp them
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
ya, you can strap the sundowns lower. my 1500's were strapped at .5ohm for a while. not that I would recommend doing it lol. you have to be ok with rolling the dice.
  • Who's Online   1 Member, 0 Anonymous, 683 Guests (See full list)
