94retta(219) Posted January 5, 2011 Report Posted January 5, 2011 Well its been bothering me to know exactly how imp. rise happens? If someone could explain it that would be great! BUILD LOG
kirill007 Posted January 5, 2011 Report Posted January 5, 2011 Well if the sub moves it sucks up dust into the subwoofer, this dust changes the impedance of the woofer and makes it higher. To combat impedance rise you need magical dust. ... When a coil moves up and down the coil resistance changes, and the box just changes how much the coil moves at certain freqeuncies. Thinking is the root of all problems... You ALWAYS get what you pay for.
94retta(219) Posted January 5, 2011 Author Report Posted January 5, 2011 Well if the sub moves it sucks up dust into the subwoofer, this dust changes the impedance of the woofer and makes it higher. To combat impedance rise you need magical dust. ... When a coil moves up and down the coil resistance changes, and the box just changes how much the coil moves at certain freqeuncies. so some air in a can should work right? BUILD LOG
Boon Posted January 5, 2011 Report Posted January 5, 2011 Ok, to explain it roughly in 'laymans' terms... A conventional speaker driver uses a coil moving in a magnetic field. When you move a coil through a field it induces a current through the coil. (Keyword: Inductance) This current is in the opposite direction from that in which the drive current is running through the coil. Obviously it is quite a lot less than the drive current but nevertheless it impedes the flow of current (Keyword: Impedance) This impedance (AC impedance, Z, is very very different to DC Resistance, Re - both are measured in ohms though) is what causes 'impedance rise' 10.x volts fo' life!
korey_hofer Posted January 5, 2011 Report Posted January 5, 2011 just to make it clear, you will need impedance rise if you want your subs to last. Subs won't take anywhere close to the power people think they are giving them going by amp ratings previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
