bigmescan Posted January 5, 2011 Report Posted January 5, 2011 (edited) Are these 2 things the same or diff. I'm assuming they are the same Edited January 5, 2011 by bigmescan Quote SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
nautical7 Posted January 6, 2011 Report Posted January 6, 2011 They're the same, any reason why or just curious? Quote
white4d96 Posted January 6, 2011 Report Posted January 6, 2011 Not quite. A tensioner is also an idler, but not all idlers are tensioners. I seem to recall seeing idlers on some small block chevy's that were not idlers. Quote Too many projects, too little time...
bobonit Posted January 6, 2011 Report Posted January 6, 2011 Not quite. A tensioner is also an idler, but not all idlers are tensioners. I seem to recall seeing idlers on some small block chevy's that were not idlers. That sounds right. A tensioner pulley is an idler pulley that is adjustable so it can apply tension to the belt. An idler pulley is just to change the path of the belt. Quote 97 Maxima SE Bunch of shit going in, check out the build Build Log
