Hey guys this is my first post here but have been browsing for some time now. I have designed a box for 1 18 either the Sundown z .2 series 18 or the T3 T.2000 but thats for another time. My reason for posting is to get opinions on the box I designed. Im wondering if the ports will work like this? Also if this is ok woofer placement. Im going to be adding 45*s, dowel rod bracings, and maybe some fiberglassing.
Im here to learn so if you see flaws please let me know so i can learn.
Here are the dimensions
Here are the sketchs I made in google sketch up. Be easy these are my first ones.
This will be going in the trunk of a 2000 grand marquis and powered by either a 2200 or Hifonics brutus 2600
2000 Grand Marquis
Digital Designs 9512
Rockford T2000bd1
Thanks i was hoping to learn info like this. Should i then move the sub to the opposite side of the ports or keep it in the middle?
2000 Grand Marquis
Rockford T2000bd1
if you put the ports exiting the right side of the box I'd move the sub to the right as well so all the air move toward the end of the ports.
2007 caliber
2 Fi ssd 18's
rd audio 3250
xs power d3100 (need 2 more)
stock alt (soon to be singer 350a)
2.75:1 4th order in progress!
should be fine where it's at. At most id move it more away from the ports, but dont let the ports get in the way of the sub. Put both ports in the same side, and im guessing youre not flaring those? Cause you should, or atleast a little.
2006 Nissan Z Track.
My Feedback Thread
Ok thanks Guys
And for flaring the ports i thought about it but i couldnt come up with any ideas i was planning on just using PVC Pipe, also flare on both ends or just exiting?
Edited by 00mgm
2000 Grand Marquis
Rockford T2000bd1
Ok say i wanted to do flares do you guys have any ideas or meathods.
2000 Grand Marquis
Rockford T2000bd1
Could i just router the edges of the port with a rounded bit
2000 Grand Marquis
Rockford T2000bd1
