Also wondering if AQ 10's would be a sensible option, the sdc2.5's specs are comparable to dc lvl 3s
ied go with sundown just bc of the fact of there thermal power handling.. never seen a a sd 2.5 take the abuse a sundown sub has. or say a dc level 3 with 4 coils increase handling about 30%
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
So even though the power handling is the same spec on aq and dc lvl 3 the dc will take more abuse? BasicLly the aq is rated accurate and dc is underrated?
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
Yea kinda, i think it has a lot to do with the cooling as well, the level 3 has a 3" coil, which most subs, including sa's dont, having the extra area lets the heat dissipate (go away) faster. I haven't seen the tests that the sa-12s go through put on the level 3, but the sa-12 seems way better built than the sdc2.5. I would imagine the level 3 and sa would be really similar in their output and handling though. I honestly see the level 3 being able to handle a little more because of the 3" coil though, and it's aluminum
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
Hammerdown... 1%
I don't have enough room behind my rear seat for anything but maybe my amps. I am really leaning towards the lvl 3s I hve ruled out 12 due to space limits but it's still between sdc 10s lvl 3 10 s or hdc3 10s the hdc3s cost the most and I'm not sure how much better than the lvl3 it really is
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
I would do 2 HDC3's on both the AQ2200's if you have the room, but only if your able to go ported....also since your gonna be a bit tight on space, go with the Copper Coil HDC3's since you box is probably gonna be closer to a cube a piece per sub ported, so about 2 cubes after displacements(give or take a bit) and since your feeding the AQ's double power the smaller box will help with control.
Edited by CaptainzPlanetz
¿ǝɯɐƃ ǝɥʇ
So if I'm not able to go ported , would you go with the lvl 3s on one amp sealed? Im just worried about the box being too wide and being too close to my doors to fire ports out each side of the box which will really be the only place I can fire them
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
That would probably be one of the better options if you need to go sealed, also it might be a good idea if you go with the LVL3's to get the coil upgrade, just to make sure they handle the power
¿ǝɯɐƃ ǝɥʇ
So i'n your opinion lvl3 with 4 coil > hdc3?
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Bose mids and highs
0 gauge Knu wire
Big 3
In a sealed application yes, in a ported application no.....the AQ HDC3 10's are little beasts, I have one sitting write next to be, thats going in my car soon, before this I had a DC XL15 and I would say this is about the same weight as it, but I just needed a sub that takes up less trunk space, and have always wanted to try AQ, so thats why I picked up this sub.
¿ǝɯɐƃ ǝɥʇ
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
