i currently have 1 RFt1k ( new model ) running off a stock batt and a stock alt. which is obviously too much power for the battery because a little bit of acid is on one of the terminals so my questions are.
since that amp doesn't have that much power would the acid leaks stop if i just bought another battery and use it as a primary? something like a yellow top.
or should i buy the yellow top and put it in the back? which leads to my next question if i were to do that would strapping another stock alt even work to charge those 2 batteries..
First off you need a new battery if it is leaking acid. Secondly, it would be wise to get a AGM style battery, much better for car audio, and depending on the size of the AGM you select, that may be all you need, also considering the size of your alt. I would need to know more info about vehicle.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
as long as your not cranking the gain to full clip and listening to it full tilt all day, you should be fine with a stock alt and stock batt, But you should do the Big 3 upgrade.
it wont hurt anything to add a yellow top to the back,
you wont need 2 alts for a 1k amp,
You don't need two batteries either.
Evo X build log
Leaking acid. Get new battery most likely. if you dont go gain crazy 1k is fine on stock electrical. I ran 1800rms on stock electrical and big 3. (105 amp alt, nice interstate batt)
ok its a 2008 acura tsx, the alt is only 110amp i believe. but i thought i would need 2 alts because i didn't think 1 alt could charge 2 batteries lol.
X2, get a nice AGM upfront and you will be good to go.
This with the big 3 and you should have little to no voltage drop.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 2212 Guests (See full list)
