Here's the equation to estimate amplifier current draw:
Watts/volts/efficiency= amperes.
I multiply the amperes by .5 because music isn't constant tones and there's always a change in impedance.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
If you are running them both at 1ohm you're gonna need alt and some batteries. I'd suggest a 260-320 amp alternator, the biggest XS Power battery you can fit up front, and then a D3100 or combination of smaller batteries (whatever you can fit) in the back.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Really depends on how you have them wired, strapped or not and at what ohm load, those amps make a good amount of power strapped at a low ohm load. Also depends on whether you are talking about burp or music as well.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
You will have a max of 5000w out of those 2 amps. To get the maximum performance out of them, you will need to keep your voltage as high as possible. You can figure that those amplifiers will pull max of 200 amps each. For this setup, I would get a 270a alternator along with whatever size XS battery will replace your stock location and add 2 XS 3100s in the back. The equation I like to use for figuring out how many batteries is take your max RMS watts and double it and buy batteries accordingly. The 3100s will handle 5000w+ each. With 2 plus the battery under the hood, you should have somewhere around 14000w of power handling in the batteries. With this you should see minimal voltage drop at full tilt.
So you have clamped the 2200 strapped at .5 ohm and know they do 5k, what was the AC voltage and AC Current? LOL
Evo X build log
Just going off of 1 ohm specs. If he has to ask this question, then I wouldnt recommend running any amp below factory spec. I am sure the amp will do over rated power in the right application and built by someone who knows what they are doing. Even if he were to see 6-7k out of the amps 2 3100s and a stock replacement XS Power Battery and a 270amp alt would be sufficient.
Yeah agreed. Carry on, but OP we really need to know what you are wanting to do with the amps, and what you are connecting to them. Because if you are just going to play music thru them and only get around 4k or less out of the pair, then no need for 2 xs 3100's.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 2212 Guests (See full list)
