4 z V.3 18s 18v and a big 4th order
I have seen a d din in the stock display area before.
A fairly involved install.
Not really something for a rookie to try out.
Just tryin to help man.
Its a lot tighter back there than you realize.
yeah i started to figure that out once i pulled that dash piece off is there anything i can do i really hate the other option
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
just a mock up of how the subs go in
ooooooooooo :good:
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
ive seen it done by extending the dash over to the right. about a 2" ext.
looked a little weird when done.
uhh.
it can go in the middle with slight mods.
the main issue is the servo for the floor vent/ a/c vent/ defrost is in the way.
It can be re-clocked out of the way.
I have done that before.
Id do a console if i were you.
way easier.
i guess ill settle for now with a single din in the center <_<
WAIT... so the newer dashes work in the older trucks? am i getting this right? i was gonna do a build in my grandfathers 95 burban but i cant stand the dash, i can swap it for one of the newer gen ones? am i getting this right?? mind = blown.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
i figured id show you what i have to work with
real engines have 8 cylinders
8 cylinders are little motors! Looking good so far though :)
"WHOEVER SAID MONEY CAN'T BUY HAPPINESS MUST OF BEEN BROKE"
The 95 burban already has the new dash
not ours. its the older style. the same as our 92 c1500.
