4 z V.3 18s 18v and a big 4th order
this is what will seal the front of the box so i can make it removable to be able to get to the subs
new rubber the last one wasnt the right part so i got a replacement for free
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
its getting REALLY close to time to be cutting a hole and nobody seems to care
I had a lot of fun cutting my blow thru ... A very interesting setup ... I was told not to square the corners because the boot would not secure correctly ... Best of luck to ya bro ... I'm tuned in ... Randal ...
yeah it makes sense to leave a little bit of a round edge i also plant to use plenty of silicone
You might want to ask around but urathane may work better than silicone ... Neither was needed with mine ... My enclosure was built in sections so the enclosure goes from my cab thru the opening (blow thru) and just using the bed of the truck for space ... If you look closely, the enclosure doesn't even touch the bed floor ... And barely touches the front bed wall (except for the secure mounts) ... Just a suggestion for something to check out ... Thanks, Randal
Friday ill be off........ ijs
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
the only time i dont have work is the weekends
Shit too early to say what my wife will make me do
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
