Mechman Alternators
HELP! Brand new 270 low charging out put!!!!
Ok so I just got all 3 of my 270's and have them installed... I only have the one in my stock 2pin position, waiting to hook up my MLA for the other 2... Well it works perfect no dash codes or nothing and last night I installed the first of 7 d3400's up front in the stock location I checked it all with my DMM and set my voltage meter inside the truck... It was charging all night last night around 14.8-15.2 now.... I can't even break 14.0??? It's resting at 13.7 even when I rev or drive it doesn't break 14 ?? WTF?? Each alt has upgraded 1/0 grounds and 2 1/0 (+) to the battery
If I shut the truck off and re start it the voltage goes back up to 15.2 but then slowly fades all the way back dwn to 13.7 over like 2-3 min
SOMEBODY help me out I have to get this figured out soon
Thanks
Blake
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
i don't think you'll be getting a resting voltage over 14 volts.. 13.7 sounds pretty good to me .. i wouldn't complain.. i get a steady 14.6 volts with the car on though.. and it rest at 13.2
at start ups.. it will jump high.. that's completely normal until the engined has warmed up enough....
Edited by speedball1978
Yea I understand that but all last night while driving and or rev'd the voltage was 15 or rly close... Now the voltage nvr breaks 13.8v ??? Somethin is wrong.... I checked all the wiring and everythin is fine??? I'll check the alt post when I get out of church.... I'm just wign out bc Im already pushing my deadline to make it to Carl Casper next month gota figure it out
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
What year suburban do you have? It may be because of that stupid gas saving feature
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
some newer cars have ECU controlled voltage regulators. so unless the computer doesnt see a load it will drop the voltage. why? no freaking idea. try going moderate volume or full tilt and see if the voltage increases.
x2 on what kranny said, ive had to do it in shop class to see if the alternator still was good, it charged at 14v and once on a load it sped up to 14.6.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
This is what I meant
LMFAO so true
:blush:
My suburban is a 2006 it's the first year of the LTZ edition It is the 2 pin that does regulate the voltage, but say my voltage is at 13.7 and I roll up all 4 windows, and have the heat on n shit tryn to put a load on it goes down to 13.3 and doesn't go up till I let off the switches... Maybe it will be ok when I hook up the MLA and the other 2 alts...?
The only reason I freaked out is bc last night the truck read 14.8 all night, but I was thinking to my self that may have been bc the new battery wasn't fully charged, the resting voltage on the battery before I put it in was 12.1 and now the resting voltage with the truck off is 13.2 so I'm guessing that may have been what the computer thought was a "load"???
Thanks guys!
Btw I'll be at Casper sat most likely but maybe Sunday too? Not completely sure on that
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
  • Who's Online   0 Members, 0 Anonymous, 1870 Guests (See full list)
