ChevyBoy Posted October 14, 2006 Report Posted October 14, 2006 better reserve, u can let them go dead and charge them rite back up, more ampheres. a lot of things. Quote
iceman88 Posted October 14, 2006 Author Report Posted October 14, 2006 kk.... Theres 2 problems for me now..... finding a cheap yellow top, and SPACE! major one is SPACE, my enclosure takes the whole of my boot, and i dont have any space what so ever..... Ohh, im thinking about taking out the spare tire, lol i just brought a EQ of ebay.... Quote
dmanson Posted October 15, 2006 Report Posted October 15, 2006 you can throw the battery where the spare tire is. Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
iceman88 Posted October 17, 2006 Author Report Posted October 17, 2006 Dham i just couldnt resist, I got my self another JBL 1201.1 1200 Watts RMS, and at the moment im pushing 2400 Just off 4 gauge wiring, Now that created LOADS more problems, i now need anothe run of 4 gauge minimum to the second amp as pulling it from the single cuts it off.... I DEFO need yellow top in back now... and im going to change the stock battery.... hopefully that should sort stuff out, but man now i got the 2 amps, wiring looks terrible.... i defo need some advice ideas on how to keep it clean.. also pics would help loads! Quote
ChevyBoy Posted October 17, 2006 Report Posted October 17, 2006 Dham i just couldnt resist, I got my self another JBL 1201.1 1200 Watts RMS, and at the moment im pushing 2400 Just off 4 gauge wiring, Now that created LOADS more problems, i now need anothe run of 4 gauge minimum to the second amp as pulling it from the single cuts it off.... I DEFO need yellow top in back now... and im going to change the stock battery.... hopefully that should sort stuff out, but man now i got the 2 amps, wiring looks terrible.... i defo need some advice ideas on how to keep it clean.. also pics would help loads! advice u say? get rid of the damn amp till u get enough power to run it be4 u fry something possibly both amps Quote
andym85 Posted October 17, 2006 Report Posted October 17, 2006 well, we tried to warn you... :-X ...anyways, YOU NEED TO BEEF UP YOUR ELECTRICAL BADLY, as with most beginners this is an oversite and sometimes leads to bad things... i.e. fires, fucked up amps and such. as for keeping your wiring clean, just run the wire underneath the carpet and wire tie everything, its really not that hard, it just takes time Quote i likes me some audio stuff...
iceman88 Posted October 17, 2006 Author Report Posted October 17, 2006 lol ohh dont worry about tht already done that when it kept cutting off, at the momment i've disconnected one of them and one amp running both subs.... ;D Quote
dmanson Posted October 18, 2006 Report Posted October 18, 2006 man get you some 1/0 gauge and fuse that bad boy with a 300 amp fuse and put your extra battery in the back and fuse the 1/0 gauge before the 2nd battery. you'll be good to go man, forget adding another 4 ga. that's useless with that much power. Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
GHOPPOMAN Posted October 18, 2006 Report Posted October 18, 2006 if space is an issue go with the kinetic batt. u can get more power in a smaller size than the optima. i use kinetics myself and wouldnt change them for anything! Quote
dmanson Posted October 18, 2006 Report Posted October 18, 2006 you do what we've recommended and you'll be well on your way broham. i like the kinetic junts too or either batcap, either or will do a great job. good luck Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
