Battery rating questions?
This might be a dumb question, but I've been trying to pick a battery for my car, either a second one, or to replace the starter battery. I know the basics, AGM and such, but i'm not sure about the ratings i should look for, A lot of batteries state the CCA, while some only put the amp hours, and some have an amperage rating, and some like xs power even have wattage ratings. basically i have a 1700 watt amp, a 760 watt amp, on top of the factory amp, which is probably pretty small, it's not just a HU, it has an amp... mostly i'm just wondering what ratings i should be looking for on all the batteries available? also i know i could Exceed what i need, but i'm on a budget, so i'm looking to get the one that is just big enough to handle what i'm running.
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
The ratings on batteries are mostly meaningless when it pertains to car audio. Assuming that you have a stock alternator and are drawing what I am going to guess about 200 amps between your amplifiers, I would just add something along the lines of a XS D3400 in the back. I would also make the big 3 upgrade and have 1 run each of +and- front to back and you will be good.
I have 0 awg big three done, but my headlights dim a bit, and i do have a stock alt. so d3400, any alternatives, i know xs is the one everyone on here recommends, but are cheaper ones, like kinetik really that much worse?
2009 Cobalt LT
Pioneer Headunit
4x Pioneer 6 1/2
Pioneer GM-6400F
To come:
^^ this. I'd also put the biggest XS Power/AGM battery up front. I don't like mixing battery types.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
After talking with jeff it seems like xs's technology is really ahead of everyone else and you can get a smaller battery to keep up with more audio for a similar price, so I've yet to find a reason not to go with xs
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
For the money XS is worth every penny. I have personally run Stinger, Kinetik, and XS Power Batteries and XS holds almost 1 volt higher than the others in my setup.
That's all well and good, but up there ^ he recommended a d3400, that's 1000 ca, 65 ah for $270, a kinetik hc1400 is the 1400 amps, and 60 ah for 139.99.... I can't say it will be the same quality, but i'm not running an SPL setup or anything, and i find it hard to believe that the kinetik won't cut it...
2009 Cobalt LT
Pioneer Headunit
4x Pioneer 6 1/2
Pioneer GM-6400F
To come:
  • Who's Online   1 Member, 0 Anonymous, 445 Guests (See full list)
