HotRodHam Posted January 18, 2011 Report Share Posted January 18, 2011 ok so my front right tire is wearing on the inside alot and ive gone through 2 tires because of this so far. and i was wondering wat could be causing this. and my back right tire has one massive bald spot on it like someone pulled the ebrake and just sat there burning out. wat could cause this Quote 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200 Link to comment Share on other sites More sharing options...
Pitbullx Posted January 18, 2011 Report Share Posted January 18, 2011 ok so my front right tire is wearing on the inside alot and ive gone through 2 tires because of this so far. and i was wondering wat could be causing this. and my back right tire has one massive bald spot on it like someone pulled the ebrake and just sat there burning out. wat could cause this depending on how wide the wear is on the front tire its either too much negative toe or too much negative camber either way go get your alignment checked out.... as far as the bald patch if you havent ripped the e-brake you may have a caliper that is sticking.... Quote Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio Link to comment Share on other sites More sharing options...
zayres29 Posted January 18, 2011 Report Share Posted January 18, 2011 get an alignment Quote Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged Link to comment Share on other sites More sharing options...
Steph3n1 Posted January 18, 2011 Report Share Posted January 18, 2011 ^ what they said. allignment appears to be your problem but them again it could be your balljoints going bad get them both checked Quote 2005 Ford Ranger Reg cab Build in Progress T3 Audio T2000 12 ARC SE4000 Stinger HPM 1/0 Wire DC power 270xp Batts: 1 Redtop up front and a Stinger SPP2250 in the back Hopes to be in and around a 150....weel see my youtube channel http://www.youtube.com/user/steph3n1 Team DBs (Driven By sound) Link to comment Share on other sites More sharing options...
craniumcrackinbassv2 Posted January 18, 2011 Report Share Posted January 18, 2011 if you lowered or raised your car that will seriously throw the allignment off. also hitting speed bumps and potholes to hard will throw it off. i had my tsx on a some coilovers and when i took them off my allignment was really bad. Quote Link to comment Share on other sites More sharing options...
craniumcrackinbassv2 Posted January 18, 2011 Report Share Posted January 18, 2011 if you lowered or raised your car that will seriously throw the allignment off. also hitting speed bumps and potholes to hard will throw it off. i had my tsx on some coilovers and when i took them off my allignment was really bad. Quote Link to comment Share on other sites More sharing options...
Ford302Redneck Posted January 18, 2011 Report Share Posted January 18, 2011 A little late to ask? But I guess better late than never. I would of researched why it did it after the first tire, not the third. I'm sure your local alignment shop can take care of this for you. Quote Link to comment Share on other sites More sharing options...
