help with some dirt bike problems?
how deep of water you go throught and if its a 4 stroke and was somkeing it could be fule air but kinda sound like water pump gasget. dose your oil have coolnt in it? if it does it would look milky.
that can stop a bike from runing right and take all the power away.
(94 thunderbird)
Alpine head unit /doors, minds, hi's
Power acustik Eq with in line boost.
Alpine door amp.
Fi btl fully loaded 18"
custom box in back seat 10 cube ft at 32 hurts.
Power acustik 5500 d gothic 3200 rms @ 1 ohm
2 batt's / big 3 / 0 Gage wire 2 runs.
(Josh boucher)
Start with simple stuff first. Clean the carb real good and then see how it runs. the go from there.
formerly known as Jaylor Swift
you didnt happen to put 2 stroke fuel in your bike did you? or its just old fuel. and what comes with old fuel is deposits that get caught in the carb.
no, i had the bike sitting for awhile, while i was gone on a trip my dad tryed changing the oil and put a higher weight in it and started it, i drained that oil and put the correct amount, then my clutch plates stuck so i made some cable adjustments and let the bike warm and problem fixed. when i went to ride like i said it didnt feel like there was much power at all and stalled a couple times...so i just packed up and went home so i wouldnt make it worse
if your not scared.. when that happend to my atv... we would go to the local airport and get some air plane gas and put it in there.. you DONT NEED ALOT prob like maybe 2 bucks worth... and i promise you the bish will move like its new.. or use some seafoam.. the boring way..
air plane gas? haha i didnt even know you could do that...i think ill try replacing the oil first...then the oil...then the air fuel will probably be a last resort. did it run fine after you did this? did it fix the problem?
with all the ethanol in gas nowadays the shelf life of gas is two weeks.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
come to think about it the oil did look a little milky, how would i fix it?
caution.. air fuel is leaded.. not the best thing to do.
new gas/carb rebuild and marvels mystery oil is the best way
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
i refilled the bike when i was riding but it had some old gas still in there so hopefully it will flush it out
air fuel will be a last reserve for sure, i really hope no engine damage has been done. i really dont want to pay the money to get it fixed
well ethanol still eats at gaskets if it sits for a long period of time.. and causes varnish
note to you.. when your done riding shut the gas off and run it outta gas.. no more problems..
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
