DC Sound Lab
i am so confused..
u should be i didnt get to finish postin all the damn pics from my 2 years of progress, threw the two cars i started with 1 18, on two saz 1500s, got a lvl 5, got another, got an SD 8k and built the box that was a miserable fail, switched cars, and am now starting over with 2 lvl 5 12s and 2 lvl 2 8s on a sundown 1500 and the 5's off the 8k
with a rainbow and alpine amp on the highs with 3 component sets and a couple coaxals
the new car was completely baige and the old green and black, all off the old door pannels got moved to the new car, along with all of the stereo crap, but im switching to the lvl 5 12s to gain trunkspace, and do my final build in this car, hopefully
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
Haha gimme 2 days and it will all make sence
SCSB
Build logs:
i dont know what is going on here
what car do you have what setup is in it
and it looks like you need some box help if so PM me
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
The new box is the last box, i just havnet cut and routered the holes yet because im getting the baskets tommarow i have the motors cuz i had two lvl 5 18s
I have a 2000 grand marquis the black one that was once green.... i just bought the 1999 grand marquis and switch into that car and scrapped the beater car
SCSB
Build logs:
i am sooo lost right about now
NoFearX18 said:
trainman0978 said:
Finally got your 12s huh. I hope that box design works for you i dont know. I would of cut behind the seat out to fit a front fireing box with subs and port fireind forward then sealed it off real good. then put those 8s in you rear doors. BUt if what you are doing sounds good leave it. try and make it to our bakersfield show march 5th. ill introduce you to my teamates
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
I would do subs forwar if i could there is just no room, its oly 11 inches tall with the trunk bars, so no way
I have very good luck wit the 18 sub back port forward.....
Imma reorginize my pics so they are so busy and everyones one cunfused im super bust rushin to get this thing back together.... the 8"s are sick on the deck tho
SCSB
Build logs:
SCSB
Build logs:
