RD AUDIO 3250.1 CLASS D LINKABLE MONOBLOCK AMPLIFIER
Specifications
RMS power, 2 ohm linkable/dual mono5600w x 1chRMS power
, 0.875 ohm mono3750w x1chRMS power
, 1 ohm mono3000w x1chRMS power
, 2 ohm mono1500w x1chRMS power
, 4 ohm mono750w x1chRMS power
Signal to Noise Ratio>100dBLow pass frequency crossover35Hz~300HzSubsonic filter10Hz~60HzBass boost @ 45Hz0~18dBPhase shift control0~180 degreeFrequency response10Hz~350Hz (+/- 1dB)T.H.D @ 4 ohm<0.1%Efficiency @ 4 ohm86%Fuse rating300A(external type fuse - not included)Input Sensitivity200mV to 6V (+/- 5%)Dimensions222(W) x 52(H) x 590(L)mm
if you arent sure and the deal is too good to be true Id avoid it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
pretty sure the first ones didnt do nearly close to rated and had fireworks issues. Im not a fan of RD audio at all so I didnt pay too much attention. do a google search and you'll be able to find some stuf.f
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
If you don't know why post?
To the op that amp in the picture is a first version and is a Zenon board amplifier(Korean). Its a really good amplifier same as the original of Sundown 3k, Atomic 3k and DC Audio 3k and close to the Crescendo 3k. The first version didn't have firework issue's, it was the second version that had issues. They changed build houses and some of the amp were faulty. The amp is a power house and will do every bit of 3k all day without issues and with a good electrical will run at .5 ohm all day making over 4k. I have 2 of these amps and have ran them as low as .25 ohms without problems with a VERY strong electrical to back it up. These amps are a great amp but don't retail or go for anywhere near what you see the Sundown 3k's or even the DC 3k's go for.
Edit: Also this amp looks like it has been through a lot, I wouldn't pay much for an amp in this condition.
Edited by etaks_crew
and for a starting bid of .99 with free shipping what do you have to lose?
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
IIRC the first versions were good but then RD changed something and most of the V2s turned into fireworks
TEAM DC
Everything is a 150 on th earometer
Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw.
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
You must run rd because its the first decent thing ive ever heard said about them and I was posting to give him something to look into. my mistake that I had the v1 and v2 mixed up.
http://forum.ecoustics.com/bbs/messages/4/597243.html
Thats enough for me.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
