thanks. Im not worried about cost. I am just wondering what other causes are. I am going to get the wheels balanced also.
Wheel alignment is about double that cost around here. So adding in the balance i am guessing around 120 for everything.
holy shit man...thats nuts. Wheels cost 5 bucks each to balance here and about 40 for an alignment. But if you know someone, its about free ;)
But yes, you need a front end alignment, in the end itll still be cheaper than new tires. A number of things can cause un even tire wear, like bad ball joints, wheel bearings, or worn tie rods.
And chances are, youll go in and they will tell you your tie rod ends are bad and etc. Thats how they make their moneyyy
if its bad its bad, there is no way to do an alignment if the parts are bad..... any halfway decent mechanic will show you where the parts fail
Nasty camber wear, align it and be done with it.
actually its probably the toe that is is out.... the camber will only wear on the inner or outermost edge of the tire... if its a wide wear toe is the culprit
^^ and ask them to shake down your front end could be a bad pitmen arm or somthing like that,
gotta do a shakedown before it can be aligned, trying to align a car with bad parts is pointless since the angles will be thrown out the second the car hits the road
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
ya. get it aligned and your troubles should be over. well, i should say the alignment issue will be over, but if the tires are already really worn, then you should probably replace them.
Pioneer AVH P5900DVD
JL Audio XR525 CSi Components (Kickpanels)
Infinity Reference 6020cs Components (Doors)
JL Audio 12W7 Subwoofer
JL Audio e1800D Amplifier
JL Audio e4300D Amplifier
Pit, he stated in the first post that the inside edges of the tires are worn.
Guess i need to add to my sig " ASE Certified Technician in brakes and front end and alignments" ect.for the last 15 years so people dont just think i am talking out my ass when i state something on a car issue.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
The middle to the outside is perfect but the middle to the inside is non existent.
Toe-related tire wear is easy to recognize, as it is fairly distinct compared with other types. Excessive toe-out will cause a feathered wear pattern on the inside of the tire tread; too much toe-in will wear on the outsides. Toe-related wear can be distinguished from camber-related wear as it is at a much smoother angle and may spread over half the tread of the tire. This contrasts with camber-wear, which is usually only in a narrow area near the shoulder of the tire and abruptly disappears.
eHow.com http://www.ehow.com/about_5763124_causes-toe-wear-tires_.html#ixzz1CDD9xZS7
Now I could be reading too much into his description of the wear issue and it very well could be a camber issue but if his description is accurate then it is a toe issue. And nobody said you were talking out of your ass so calm down homie, its all good. BTW I have been master certified tech since 1998 A1-A8 (A9) and I am certified to teach the alignment course through Hunter should I put that in my sig 8) I did about 50 alignments a week on avg
I'll bet its a control/a-arm bushing out or tie-rod end that are worn/gone.
Hammerdown... 1%
