Looked at my front two tires and they look normal at a glance...until you turn the wheel.
The insides are worn down super bad.
The middle to the outside is perfect but the middle to the inside is non existent.
Now i replaced my front shocks a year and a half ago and didnt get an alignment like i should have but is this the main reason? Lower ball joints have also been replaced.
The car shakes around 70mph and above...until of course yo reach 100 and its smooth as glass. Under 70 it also drives normal.
But the main question...is the front end alignment usually the fix to this problem? The tires will be rotated to the rear...those tires are perfect.
Eclipse cd7000
its an alignment issue.
Thought you said you had an alignment done. Sorry. But yes, pay the 40 bucks and get it done right.
Edited by PlugItIn
thanks. Im not worried about cost. I am just wondering what other causes are. I am going to get the wheels balanced also.
Wheel alignment is about double that cost around here. So adding in the balance i am guessing around 120 for everything.
Eclipse cd7000
holy shit man...thats nuts. Wheels cost 5 bucks each to balance here and about 40 for an alignment. But if you know someone, its about free ;)
But yes, you need a front end alignment, in the end itll still be cheaper than new tires. A number of things can cause un even tire wear, like bad ball joints, wheel bearings, or worn tie rods.
And chances are, youll go in and they will tell you your tie rod ends are bad and etc. Thats how they make their moneyyy
Edited by PlugItIn
Nasty camber wear, align it and be done with it.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
It is possible that because the ball joints were bad it could have caused them to wear.So as long as everything is tight on the front end,getting the front end lined up should take care of any future wearing .
Member of Team 808
Member of Team North East Spl
have the ball joints check if you have them. tie rod ends and some of the suspension bushings. i doubt the pitman will cause tire wear. it will cause loose steering. have the bearings checked and packed if possible. what kind of car is this?
Team DBs (Driven By sound)
thanks guys. heading up to meineke in a bit. the car is a 93 dodge stealth base model (sigh i know, NA)
But this car has been very good to me.
Eclipse cd7000
A bad axles can cause it vehicle to shake too.. Does the steering shake or no?
