EclipseChris Posted January 24, 2011 Report Posted January 24, 2011 ok because im buying an xs battery as a primary and i have a pair of 0GA terminals that cover the entire battery terminal so i was wondering how is it possible to reconnect the original connections if the terminal is completely covered. i thought there was just more that went into recharging a primary battery than just a 0ga to the alt and another to a ground lol. Here is how i did mine in the first few stages of my build. The stock alt wires and computer wires are still there, right on top of the amp wire (big red wire). Quote i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
SQMonte Posted January 24, 2011 Report Posted January 24, 2011 In most cases (like mine personally) you are REPLACING the original 3. But in some cases (like the ford focus) If you do not still have the stock terminals and wire the car wont start, so you must ADD onto, not replace. adding vs replacing is pretty much a matter of personal preference, theres no right or wrong way when it comes to that. Quote Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f
speedball1978 Posted January 24, 2011 Report Posted January 24, 2011 i left mine on until i got my new battery under the hood, then i ditched the stock wires except the one going to the fuse box and the starter, they remain Quote
craniumcrackinbassv2 Posted January 24, 2011 Author Report Posted January 24, 2011 ok this is what ill do, im going to pick this thread back up later because i have a test to study for. when i am done ill take a pick of the positive connector ( which looks like a damn brick with a ton of wires that are running from it) and post it up. i have an 08 tsx which is a MF to work on so we'll how it goes. Quote
SQMonte Posted January 24, 2011 Report Posted January 24, 2011 i always add on, except for the batt ground to chassis wait so you just have 1 0ga to the alt and the original battery ground? what made u think that? u know what the big 3 is, right? out of the 3 wires that get added/upgraded, the battery ground is the only one i replace, the others i leave in place and simply add the upgraded wires to the mix. make sense? Quote Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f
EclipseChris Posted January 24, 2011 Report Posted January 24, 2011 adding vs replacing is pretty much a matter of personal preference, theres no right or wrong way when it comes to that. All i am saying it that in SOME cases there is a wrong way. Like the ford focus example i gave. Quote i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
SQMonte Posted January 24, 2011 Report Posted January 24, 2011 ok this is what ill do, im going to pick this thread back up later because i have a test to study for. when i am done ill take a pick of the positive connector ( which looks like a damn brick with a ton of wires that are running from it) and post it up. i have an 08 tsx which is a MF to work on so we'll how it goes. then all u want to do is make sure ur new terminals can accomodate all the wires that need to connect in to it. theres nothing difficult about it at all Quote Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f
dereileak Posted January 24, 2011 Report Posted January 24, 2011 adding vs replacing is pretty much a matter of personal preference, theres no right or wrong way when it comes to that. All i am saying it that in SOME cases there is a wrong way. Like the ford focus example i gave. yea, it all depends on the vehicle. If you leave the factory wiring you have more wire, which is less resistence, but may not look as cool. If you know where the wire begins and starts on each side, you can replace, but if you don't then I would leave it Quote 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
SQMonte Posted January 24, 2011 Report Posted January 24, 2011 adding vs replacing is pretty much a matter of personal preference, theres no right or wrong way when it comes to that. All i am saying it that in SOME cases there is a wrong way. Like the ford focus example i gave. so simply replacing the existing wires and battery terminals results in a no start situation? sounds to me like something isnt getting reconnected right that would cause that since all wire does is carry current and the terminal is simply the method of terminating said connection. thats interesting though. Quote Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f
EclipseChris Posted January 24, 2011 Report Posted January 24, 2011 so simply replacing the existing wires and battery terminals results in a no start situation? sounds to me like something isnt getting reconnected right that would cause that since all wire does is carry current and the terminal is simply the method of terminating said connection. thats interesting though. It was a very new car, and it threw a trouble code the first time the car was started and kicked into limp mode. Which did not let the car start again. Shit like this is happening more and more often with the new computers. Honda even has a setting that shuts off the alternator to save gas. Us bassheads are just getting screwed anymore. Quote i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
