The official guns and stuff shoot the breeze thread
Have you tried the tape on the kens trick for the cross eye dominance
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Well a change in grip is all that was needed. Also shot using my right eye and it's way more comfortable, doesn't screw with the angle of my wrist too much. Feel kind of like a derp for it being a grip issue but it's solved and I'm happy. Thanks!
It happens man. There are things you don't notice until they are pointed out by someone watching every stage I shoot I get feedback on
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Also finished up the brass maxx I had. One misfire out of 1000. Biggest peeve is that brass playing they put on the bullets. It flakes off and makes a mess when fired.
I'm not gonna give any advice for the next few weeks since I'm on meds, but what is this I'm looking at?
Rolex you sicken me.
Just let me finish my pie
~ Juice
The yellow flecks are bit of brass that came off the bullet while firing
Question.
I'm having an issue with shells getting stuck in extractor after a shot. Only happened few times during first 500 rounds. Last 150 it was keep getting jammed a lot. Prior to shooting I cleaned and oil the gun. As well as sprayed little more oil after few hundred rounds. Fired a total of 650 rounds today.
How can I fix it?
What gun? What ammo? Hows your grip? Sometimes too loose will cause it. Gun comes up and catches the shell
if the spent case id still being held by the extractor after being fired it's generally an ejector issue.
on the rear occasion either underpowered ammo is bring used and not allowing the slide to go back rearward enough to engage the ejector or someone replaced the recoil spring with one that is the wrong weight
~ Juice
