I lay it down in full sheets, starting at one edge and slowly pressing it down as i work toward the other edge...I use a microfiber towel to push it into contours...If I need a heat gun I heat the metal first then lay the deadener on top of the hot metal...if you heat the deadener you run the chance of burning it...when it turns brown you cooked it
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
