Nyaim Posted January 30, 2011 Report Posted January 30, 2011 Is it possible that this amplifier HFI55.4 run a pair of this Pioneer 6x9 600watts and a pair of this pioneer 6.5" 350watts smoothly without cutting off? Thnx in advance. Pioneer AVH3200 DVD2, Pioneer 6.5" 2 way 60 Rms Kevlar4, Pioneer 6x9 2 way 80 Rms Kevlar1, Kicker Solo-Baric L7 15-Inch 1000 Rms1, 1000Rms Hifonics Monoblock Amplifier1, 800Rms Hifonics 4-Chan AmplifierAudio Control EpicenterKicker Kx3 Crossover120AH Power cell Battery (Main)Pioneer AVH4300 DVD HU2, 500rms D.A.S 10B 10' Mids 2, 500rms D.A.S 8' Mids2, 300Rms Pyramid TW47 2" Super Tweeter2, SA-12 D4 Tuned @ 33hz @ 4.26 ft^31, 1000Rms Rockford Fosgate T1000bdCP Amplifier - Birth sheet 1576Rms1, 1000Rms Rockford Fosgate T1000-4AD Amplifier - Birth Sheet 1496RmsAudio Control EpicenterAudio Control ESP2Clarion Mcd360 Electronic CrossoverKicker KQ30 30-Band EqualizerRockford Fosgate Rfc10hb 10 Farad Hybrid Digital CapacitorYellow Top Optima (Main) Big 3
audiofanaticz Posted January 31, 2011 Report Posted January 31, 2011 yes it can... The pioneer speakers that are 600watts and 350watts do not need that much power. Those are PEAK power ratings which mean nothing. You want to look at the speakers RMS power ratings, and buy an amp that will put out close to the same RMS as the speakers (at whatever the speakers ohm/impedance is). The 6by9 are 4ohm speakers rated at 80watts rms The 6.5 inch are 4 ohm speakers rated at 50watts rms These are realistic wattages and very normal for many of these type speakers The hifonics amp you linked claims to do 55watts rms by 4 channels at 4 ohms per channel. Things should work nicely.
Nyaim Posted January 31, 2011 Author Report Posted January 31, 2011 yes it can... The pioneer speakers that are 600watts and 350watts do not need that much power. Those are PEAK power ratings which mean nothing. You want to look at the speakers RMS power ratings, and buy an amp that will put out close to the same RMS as the speakers (at whatever the speakers ohm/impedance is). The 6by9 are 4ohm speakers rated at 80watts rms The 6.5 inch are 4 ohm speakers rated at 50watts rms These are realistic wattages and very normal for many of these type speakers The hifonics amp you linked claims to do 55watts rms by 4 channels at 4 ohms per channel. Things should work nicely. Thankx much bro! also would it matter much if i added another 2 6x9's to that? Pioneer AVH3200 DVD2, Pioneer 6.5" 2 way 60 Rms Kevlar4, Pioneer 6x9 2 way 80 Rms Kevlar1, Kicker Solo-Baric L7 15-Inch 1000 Rms1, 1000Rms Hifonics Monoblock Amplifier1, 800Rms Hifonics 4-Chan AmplifierAudio Control EpicenterKicker Kx3 Crossover120AH Power cell Battery (Main)Pioneer AVH4300 DVD HU2, 500rms D.A.S 10B 10' Mids 2, 500rms D.A.S 8' Mids2, 300Rms Pyramid TW47 2" Super Tweeter2, SA-12 D4 Tuned @ 33hz @ 4.26 ft^31, 1000Rms Rockford Fosgate T1000bdCP Amplifier - Birth sheet 1576Rms1, 1000Rms Rockford Fosgate T1000-4AD Amplifier - Birth Sheet 1496RmsAudio Control EpicenterAudio Control ESP2Clarion Mcd360 Electronic CrossoverKicker KQ30 30-Band EqualizerRockford Fosgate Rfc10hb 10 Farad Hybrid Digital CapacitorYellow Top Optima (Main) Big 3
zayres29 Posted January 31, 2011 Report Posted January 31, 2011 with my experiance with maxxonics 4 channels it wont really like being wired to 2ohms i would just stick with one set of 6x9s and one set of 6.5s Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
audiofanaticz Posted January 31, 2011 Report Posted January 31, 2011 Thankx much bro! also would it matter much if i added another 2 6x9's to that? You could... if you did id suggust running them to the same 2 channels as your other 6by9s on the amp, which would result in 2 of the channels on the amplifier running at 2ohms and the amp would make 110watts rms for each of those channels.
Nyaim Posted January 31, 2011 Author Report Posted January 31, 2011 Thankx much bro! also would it matter much if i added another 2 6x9's to that? You could... if you did id suggust running them to the same 2 channels as your other 6by9s on the amp, which would result in 2 of the channels on the amplifier running at 2ohms and the amp would make 110watts rms for each of those channels. ok so one more quick question maybe silly but yhh, currently i have a pair of 460 watt 5 way 6x9's and a pair of 2 way 180 watt 6.5's if i up graded them to the 600 watt 6x9's and the 350 watt 6.5's i linked too in my first post, how much more Mids do you think i would receive? how much more of a difference would it make as to adding another set of 6x9's also taking into consideration the impact it may have on the amplifier..(Upgrade the speakers from 460-600 and 180-350 or just keep the 460's and 180's and add another set of 6x9's) Pioneer AVH3200 DVD2, Pioneer 6.5" 2 way 60 Rms Kevlar4, Pioneer 6x9 2 way 80 Rms Kevlar1, Kicker Solo-Baric L7 15-Inch 1000 Rms1, 1000Rms Hifonics Monoblock Amplifier1, 800Rms Hifonics 4-Chan AmplifierAudio Control EpicenterKicker Kx3 Crossover120AH Power cell Battery (Main)Pioneer AVH4300 DVD HU2, 500rms D.A.S 10B 10' Mids 2, 500rms D.A.S 8' Mids2, 300Rms Pyramid TW47 2" Super Tweeter2, SA-12 D4 Tuned @ 33hz @ 4.26 ft^31, 1000Rms Rockford Fosgate T1000bdCP Amplifier - Birth sheet 1576Rms1, 1000Rms Rockford Fosgate T1000-4AD Amplifier - Birth Sheet 1496RmsAudio Control EpicenterAudio Control ESP2Clarion Mcd360 Electronic CrossoverKicker KQ30 30-Band EqualizerRockford Fosgate Rfc10hb 10 Farad Hybrid Digital CapacitorYellow Top Optima (Main) Big 3
pittross Posted January 31, 2011 Report Posted January 31, 2011 yes it can... The pioneer speakers that are 600watts and 350watts do not need that much power. Those are PEAK power ratings which mean nothing. You want to look at the speakers RMS power ratings, and buy an amp that will put out close to the same RMS as the speakers (at whatever the speakers ohm/impedance is). The 6by9 are 4ohm speakers rated at 80watts rms The 6.5 inch are 4 ohm speakers rated at 50watts rms These are realistic wattages and very normal for many of these type speakers The hifonics amp you linked claims to do 55watts rms by 4 channels at 4 ohms per channel. Things should work nicely. now why people can be like u .... nice answer
Nyaim Posted January 31, 2011 Author Report Posted January 31, 2011 bump Pioneer AVH3200 DVD2, Pioneer 6.5" 2 way 60 Rms Kevlar4, Pioneer 6x9 2 way 80 Rms Kevlar1, Kicker Solo-Baric L7 15-Inch 1000 Rms1, 1000Rms Hifonics Monoblock Amplifier1, 800Rms Hifonics 4-Chan AmplifierAudio Control EpicenterKicker Kx3 Crossover120AH Power cell Battery (Main)Pioneer AVH4300 DVD HU2, 500rms D.A.S 10B 10' Mids 2, 500rms D.A.S 8' Mids2, 300Rms Pyramid TW47 2" Super Tweeter2, SA-12 D4 Tuned @ 33hz @ 4.26 ft^31, 1000Rms Rockford Fosgate T1000bdCP Amplifier - Birth sheet 1576Rms1, 1000Rms Rockford Fosgate T1000-4AD Amplifier - Birth Sheet 1496RmsAudio Control EpicenterAudio Control ESP2Clarion Mcd360 Electronic CrossoverKicker KQ30 30-Band EqualizerRockford Fosgate Rfc10hb 10 Farad Hybrid Digital CapacitorYellow Top Optima (Main) Big 3
Nyaim Posted January 31, 2011 Author Report Posted January 31, 2011 Thankx much bro! also would it matter much if i added another 2 6x9's to that? You could... if you did id suggust running them to the same 2 channels as your other 6by9s on the amp, which would result in 2 of the channels on the amplifier running at 2ohms and the amp would make 110watts rms for each of those channels. ok so one more quick question maybe silly but yhh, currently i have a pair of 460 watt 5 way 6x9's and a pair of 2 way 180 watt 6.5's if i up graded them to the 600 watt 6x9's and the 350 watt 6.5's i linked too in my first post, how much more Mids do you think i would receive? how much more of a difference would it make as to adding another set of 6x9's also taking into consideration the impact it may have on the amplifier..(Upgrade the speakers from 460-600 and 180-350 or just keep the 460's and 180's and add another set of 6x9's) Bump? Pioneer AVH3200 DVD2, Pioneer 6.5" 2 way 60 Rms Kevlar4, Pioneer 6x9 2 way 80 Rms Kevlar1, Kicker Solo-Baric L7 15-Inch 1000 Rms1, 1000Rms Hifonics Monoblock Amplifier1, 800Rms Hifonics 4-Chan AmplifierAudio Control EpicenterKicker Kx3 Crossover120AH Power cell Battery (Main)Pioneer AVH4300 DVD HU2, 500rms D.A.S 10B 10' Mids 2, 500rms D.A.S 8' Mids2, 300Rms Pyramid TW47 2" Super Tweeter2, SA-12 D4 Tuned @ 33hz @ 4.26 ft^31, 1000Rms Rockford Fosgate T1000bdCP Amplifier - Birth sheet 1576Rms1, 1000Rms Rockford Fosgate T1000-4AD Amplifier - Birth Sheet 1496RmsAudio Control EpicenterAudio Control ESP2Clarion Mcd360 Electronic CrossoverKicker KQ30 30-Band EqualizerRockford Fosgate Rfc10hb 10 Farad Hybrid Digital CapacitorYellow Top Optima (Main) Big 3
