that doesnt look bad at all... yeah like they said before.. you godda keep building the layers of paint and keep sanding... the first couple times i go over it very lightly so it doesnt get very wet... that gives it a little surface to start with... and wood filler first helps even more..
Yep, will definitely use filler next time before the primer gets laid, just makes things that much easier.
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
looks good there man.
Eclipse cd7000
now THIS is how you paint MDF. shows the prep for the edges as well.
http://shoryuken.com...worklog-191692/
That piece of mdf came out sexy as hell, with a nice mirror finish.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
mix a pretty hot batch of bondo (don't overdo it) slather it on fairly thick where ever you see a dip or raised area on the box. Wait until its dry enough to where its very hard to chip with your finger. Grab some 200 grit and a DA sander and get it somewhat level. then hit it with 300 then 400 and it should be good to go. Dont use resin its WAY more dificult to shape and sand.
Edited by Steph3n1
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
Thanks guys, I'll keep these things in mind for next time. Box isnt perfect but for my first one i think its not too shabby.
