RcCustoms33 Posted February 4, 2011 Report Posted February 4, 2011 First off I would like to say how great this site is. I have learned a lot by just reading thru the forum. I have an 89 s-10 blazer I'm working on and would like to relocate the battery to the back. I will be running 2 kinetik hc2000s. Is it ok to run 1/0 gauge from the alternator to one of the batteries in the back and the wire the other battery in parallel? Or should I just keep one battery up front and one in the back? I would like to keep the engine bay less cluttered if I can. Thanks for the help.
michigancapri92 Posted February 4, 2011 Report Posted February 4, 2011 what i did was run 1/0 from the back of the car to then front and i have 2 distro blocks in the engine bay one has the 1/0 going on with 1 4ga to the fuse panel another 4ga to the starter i then have another distro that T with the main 1/0 to the back that connects to the alternator then upgraded engine grounds with 1/0 and ground the batter to the frame in the back, thats what i did at least no battery in my engine bay Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
RcCustoms33 Posted February 4, 2011 Author Report Posted February 4, 2011 Oh ok thanks for the reply.
Socky Posted February 4, 2011 Report Posted February 4, 2011 Should be fine, as long as you run longer starter power wires and computer etc... Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
tonedeaf Posted February 4, 2011 Report Posted February 4, 2011 I did this on my car, as well as relocated the PDB (under the hood fuse box). All you need to do is use 1/0 to the alternator like normal and replace the power wire from the fuse box to the engine with 4g power wire. No need for distro block or anything, other then the fuse holder for the alternator run. It cleans out the engine bay immensely and if you do anything fancy with the engine/multi alts it really shines. Do a wire tuck too.
michigancapri92 Posted February 4, 2011 Report Posted February 4, 2011 I did this on my car, as well as relocated the PDB (under the hood fuse box). All you need to do is use 1/0 to the alternator like normal and replace the power wire from the fuse box to the engine with 4g power wire. No need for distro block or anything, other then the fuse holder for the alternator run. It cleans out the engine bay immensely and if you do anything fancy with the engine/multi alts it really shines. Do a wire tuck too. i used the distros to tie in the wires and make look a little more clean Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
RcCustoms33 Posted February 4, 2011 Author Report Posted February 4, 2011 I plan on swapping over to a carbed 355 so it should look real nice.
