Home Made Circle Jig
Namosh
Got sick of cutting holes with a jigsaw so I decided to try and make something like a Jasper Jig.
Took a piece of 1/4" plexi I had laying around.
Posted Image
Taped it up before doing any cutting to try to keep it from splintering.
Posted Image
Cut the shape out with a jigsaw.
Posted Image
Cut center hole with a hole saw. The smaller holes I melted with a torch and metal rod. (oh the fumes! :blink: )
Posted Image
Mounted it between the plate and the base on my router. And that's it.
Posted Image
I had to try it out so I decided to make a box for a pair of P2's I had collecting dust.
Posted Image
Here's the box....now instead of two subs laying around, I've got a big old box collecting dust!
Posted Image
I didn't leave the painters tape on it...I just liked the look and had some blue spray paint.
It works really good and is cheap and easy to make.
good job man! I had done that years ago too b4 I got my caspers!!!
Thanks man.
I made something similar to yours. I also used plexi to make mine. What is the smallest diameter circle you can cut? The smallest I can cut is 6.5 inches.
I've only done the 12"ers so far but I'm thinking somewhere around 5 or 6" would be the smallest.
Jaspers down to a 1" diam FTW
Well, I've got the holes made to go down probably that small but using a screw for the pivot, I can't use the holes under the base. But I guess if i used a finishing nail instead, I could go down to a really small diameter cut-out. When the need comes up, I'll give it a try.
Ive made some temp ones using 1/4" mdf, but damn, stailness would be the SHIIITTTTTTT
I also use a screw as my center point. I wouldn't even try a circle under 3 inches because I don't want what happened to Steve to happen to me.
  • Who's Online   0 Members, 0 Anonymous, 1330 Guests (See full list)
