PRE-ORDER : Skar Audio T-Series Amplifiers (Ends Oct 20th) - 4 Models NEW
We are happy to announce that the "T-Series" amplifiers are only about 8 days from arriving to our facility to start shipping out. They will be fully in stock in 8 days as stated, and for a limited time only (Today through Thurs Oct 17th) you can PRE-ORDER them at a super special price that will never be available after this week.
The T-Series was founded on the principal of us wanting to design a 5 channel amplifier independent of our other lines and offer it at a reasonable price. With that being said, there are two new 5 channel amplifiers in this series as well as two monoblocks. The 4 new models in this series are all very well built, high performance, and conservatively rated amplifiers. They also feature several nice design features, such as Tiffany RCA connectors, blue LED Lighting, and a very efficient heat sink for maximum heat dissipation.
PRE-ORDER Information
In Stock : October 18th
End of Pre-Order : October 17th
T Series Amplifiers by Skar Audio
T-1400.1D Monoblock
T-2000.1D Monoblock
T-60.4-200.1AB 5 Channel
T-60.4AB-500.1D 5 Channel
Free Shipping on ALL Pre-Orders in the USA - DON"T MISS OUT ON THIS 1 WEEK SPECIAL PRICING!
T-1400.1D Pre-Order Price = $260.00 (Normal MAP = $330.00)
T-2000.1D Pre-Order Price = $450.00 (Normal MAP = $550.00)
T-60.4-200.1AB Pre-Order Price = $260.00 (Normal MAP = $330.00)
T-60.4AB-500.1D Pre-Order Price = $330.00 (Normal MAP = $400.00)
To Order :
Please either visit our website and the specific product age of each amplifier to pre-order - or paypal the correct payment amount to [email protected] and leave a note. All Pre-Orders will ship the same day the new models arrive, which is Friday Oct 18th. The Pre-Order will end the very next day and pricing will go up to normal full MAP.
T-1400.1D Technical Specifications
RMS Power @ 1 Ohms : 1400 Watts x 1 CH
RMS Power @ 2 Ohms : 700 watts x 1 CH
RMS Power @ 4 Ohm : 350 Watts x 1 CH
Frequency Response (-3dB) : 10Hz~250Hz
Input Sensitivity : 6V~0.2V
Low Pass Filter : 50Hz~250Hz
Bass Boost (Variable) : 0dB~12dB
Signal to Noise Ratior : 100dB
Damping Factor : ~180
Fuse Rating : 40 Amp x 3
Remote Gain Control Included with Knob
Line-In RCA Connection
Line-Out RCA Connection
4 Way Protection Circuitry
Dimensions : 250mm x 53mm x 340mm
T-2000.1D Technical Specifications
RMS Power @ 1 Ohms : 2000 Watts x 1 CH
RMS Power @ 2 Ohms : 1000 watts x 1 CH
RMS Power @ 4 Ohm : 500 Watts x 1 CH
Fuse Rating : 200 Amp (External)
Dimensions : 480mm x 53mm x 340mm
T-60.4-200.AB Technical Specifications
RMS Power @ 1 Ohms : N/a
RMS Power @ 2 Ohms : 80 Watts x 4 CH + 350 Watts x 1 CH
RMS Power @ 4 Ohm : 60 Watts x 4 CH + 200 Watts x 1 CH
Frequency Response (-3dB) : 10Hz~40kHz
Low Pass Filter : 50Hz~500Hz
High Pass Filter : 80Hz~4kHz
Subsonic Filter : 15Hz~50Hz
Fuse Rating : 30 Amp x 3
Dimensions : 250mm x 53mm x 420mm
T-60.4AB-500.1D Technical Specifications
RMS Power @ 1 Ohms : N.A. (4CH) + 500 Watts x 1 CH
Frequency Response (-3dB) : 10Hz~40kHz (4CH) 10Hz~250Hz (5CH)
5th Channel is 1 Ohm Stable (4 CH is 2 Ohm Stable)
Dimensions : 250mm x 53mm x 400mm
Pictures
Edited by skaraudio
Skar Audio
www.SkarAudio.com
Phone : (888) 501-7527
At what voltage are these rms ratings at?
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
Well if it's built anything like their SK-1500.1D then it should be a pretty ballsy little amp. I dont know if you've seen the SK-1500.1 or not but its definitely not the most filled board but its got the tests to back up its number claims and then some. You should do a little research before you run your mouth and look like an ill informed idiot.
Edited by Audiofanaticz
14.4v
Skar Audio
www.SkarAudio.com
  • Who's Online   1 Member, 0 Anonymous, 1611 Guests (See full list)
