What you guys think?
islandpride684
Thanks for sharing
Im lost as to what he means by the banda needs high voltage, does he mean solid 14V voltage? like no drop at all?
He keeps saying the brazilians are alot cheaper, but you have to dump a ton of more money into getting your electrical up to par.
And if you ask someone else they tell you high voltage bad. I wish that they would figure out what you're really supposed to do. 1 plonk rated run it at two ohm two ohm rating run at four. Oh wait lee voltage over 14 no wait it's keenit under 14 they are 12 volt amps. So much conflicting info
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Idk what he means by high voltage. There are a few simple rules to running Brazilian: dont go higher then 15 volts, dont go lower then 11, dont wire below nominal impedance.
3 easy steps to follow the same way you wouldnt buy a gas powered car fill the tank with water then complain its junk most people do the opposite of the 3 rules then complain. And no actually you dont need to spend a ton on electrical to keep them going they are far more efficient then korean amps so for example my banda 3500 will pull just as much if not less then your 1500 watt korean whatever amp. The killer part is the unparalleled sound quality of the Banda id easily compare to the JL slash series.
2003 Mercury Grand Marquis LS (CVB 25th Chapter)
Alpine Head Unit
stock 6x9's
Powerbass ASA 1500.1Dx
FC 1200 krank-it up battery
HC 800 Kinetik battery
Orion HCCA 12.4 in slot ported box wired down to 2 ohms
Audiopipe 1/0 gauge wire
Rockford fosgate ring terminals
Subscribe to the Youtube page
http://www.youtube.com/user/TManMusicPage
That is of course unless hes talking about the 110 volts output of the 1 ohm amps and 220 volt output of the 2 ohm versions.
Alpine Head Unit
stock 6x9's
Here is a comment left elsewhere in regards to someone who knows more about it then I:
Brazilian amps dont like recommended resistance . If it says 1 ohm there saying to stay above that because there looking for your box rise . There tricky . If you give the amp 15v and you have a 1 ohm after rise your amp will pop. But if the input voltage is around 12-13 the amp last a little bit longer but still have the chance of popping . The amps look for 2-3-4 ohms . Brazilian amps work off your voltage/wattage not as much as amperage. So the "high voltage " is whats coming out of the amp . Brazilian 5k amp may give you 130 volt output at 40 amps@ 5,200 watts compared to a korean 5k may give you 87 volts at 60 amps@ 5,220 watts. <---- ohms law v×I=p where v is voltage I is amperage and p is powere . And too find you rise v÷I=r r is resistance. Post this on that page . I hope this dumbs it down for him .
Alpine Head Unit
stock 6x9's
I like how people just sit around and make up excuses for why the amps blow.
I'll keep my money with what's proven and durable,
you know know the stuff people don't have to come up with a million reasons for why it will blow.
which banda amp do you run to know all this?
  • Who's Online   0 Members, 0 Anonymous, 1341 Guests (See full list)
