Think i can get the 150db?
sbg
Just starting the build.
1 of my 21s just to start....
All stock eletrical, and just hooked up a 1000w amp to test quick.
Did 142.3db @ 36hz
I have a amp that does 3700w 12.6v
2 xs power d3100 and about 100ft of 1/0 wire to start with.
Box is 7cuft net tuned to 34hz
Think will will get that 150db after I put the big amp and other stuff in? Or is it just a wet dream. 0921151614_zpsmqwzz2ym.jpg0920150858_zpszxsbr13l.jpg0911151022_zpsf4hgecq6.jpg
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Is the port braced? Or rest of the box?
You could probably get a 150 with your equipment, but it doesn't happen by accident even with solid gear.
Yes box and port is braced. I still need to put the 2nd baffle on. But box has NO flex at all as it is
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
You need to just get it all in there and see what it does and take it from there, then make any changes that might be needed.
Seen a local guy drop a lot of money just to be stuck at 149.9 with a really cool install, not the best box though imo. He sold it to some guy that broke 150+ first comp in a super simple install and different box etc.
So no way of telling
True. To be real if it does 149.9 I will be fine. I don't go to shows, and it's more of a demo setup. But it would be cool to get a 5o out of it. I'm sure I will build a new box, as I most of the time build a few for a setup to see what works best. Can't wait to see what the db gain will be after adding 3000wrms to it :)
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I don't have much into this setup. Most people have more into one amp then all my build haha
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
If I were a betting man, I'd certainly bet no. I'm putting the over/under at 148.
Kinda what I was thinking, 48-49. In theory I should gain what? 7db or more from going to my big amp.. I know you can't just got of adding power 100%
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
So you are going to almost quadruple the power. In theory that will add 6 db, in practice you probably won't get that much due to power compression. This is assuming your current amp is actually putting out 1,000 true watts.
Builds:
Current amp is Orion xtr1000.1
Rated 1000wrms at 12.6v no voltage drop at all with that little guy. But I'm sure after rise I didn't see 1000w out of it...
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
