Driver's seat height adjustment doesn't work... Kinda...
'05 Tahoe LT
So.. I never noticed it until I went to pull my driver's seat out today to replace the heating pads. I tried to raise the seat so I can get to all the plugs underneath, but the height adjustment doesn't quite work. The motor turns on on and makes a very small 1/8" adjustment in either direction, but then stops. I'm a bit confused at this one.
Is there some relearn procedure or a starting point of where to look to get this thing working? I don't even know where to begin since the motor itself still works
Any fears with worn teeth?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
It doesn't sound like it's stripping, the motor just turns off/stops moving like it's hit a stop
When I go up, the relay clicks off. When I go down, the motor stalls out but keeps trying
What do you mean?
I just got the seat out and took a loot af the height motor. It's retracted all the way in to its lowest point. It has room to go up, but shuts off when it tries. No room to go down, but keeps trying
Screw is wound all the way in setting the seat to the lowest point
what happened to my friends was similiar but front to back. the left side was about 1/4" off and tweaked the seat and the motor noticed the tension and stopped as to not damage itself. it was weird as all he did was move the seat all the way forward to clean under it. had to manually remove the one side and then align it properly. also make sure something is not lodged in there.
  • Who's Online   0 Members, 0 Anonymous, 1740 Guests (See full list)
