HHR Ed Posted October 24, 2009 Report Share Posted October 24, 2009 the bigger the magnet, generally the more efficient the woofer will be. when the current is going through the voice coil, its electromagnetism is affected by the magnetic field of the strong motor, which causes the voice coil (which is attached to the cone) to move more air.kind of like comparing an Xplod to a BTL. stronger motor (along with other characteristics) is a means for a louder woofer with higher sensitivity. http://www.bcae1.com/speaker.htm http://www.bcae1.com/speakrat.htm Thats not really true, Larger motor has very little to nothing to do with efficiency and sensitivity. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion Link to comment Share on other sites More sharing options...
Bumpindemlowzz Posted October 24, 2009 Author Report Share Posted October 24, 2009 great responses guys thanks. 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts Link to comment Share on other sites More sharing options...
Kranny Posted October 24, 2009 Report Share Posted October 24, 2009 Thats not really true,Larger motor has very little to nothing to do with efficiency and sensitivity. i know its not really that true, hence i put "generally" edit: but then why does lets say, the example i gave, the xplod and BTL. both being 12" speakers, giving lets say 100w to each. the btl would be louder since its much more efficient since the motor has a MUCH stronger force (and other things) Link to comment Share on other sites More sharing options...
HHR Ed Posted October 24, 2009 Report Share Posted October 24, 2009 BL, and motor force is kinda like Torque for a car motor vs. Horsepower. A strong motor doesnt mean a woofer will be sensitive, it just means that it will have the strength to push a more massive cone and be able to push through power compression. In the higher SPL range over 155 dB, tremendous air pressure is placed on the cone as it moves. So alot of force is need to push against this air resistance, thats when powerful motors are needed. But sensitivity and efficiency is more based on the coil charachteristics and mass and weight of the moving parts as well as how the suspension allows the cone to travel. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion Link to comment Share on other sites More sharing options...
MickyMcD Posted October 24, 2009 Report Share Posted October 24, 2009 But sensitivity and efficiency is more based on the coil charachteristics and mass and weight of the moving parts as well as how the suspension allows the cone to travel. This. Cheers, Mick Work;DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS VeniceMeyer Sound CQ-1's, CQ-2's, PSW-2'sRAMSA Monitor AmplifiersP.Audio MonitorsBSS OMNIDRIVE and SoundwebDBX 231 and Klark Teknik DN360 EQ'sRCF TT22ARCF ART320 Link to comment Share on other sites More sharing options...
tripleb45 Posted October 24, 2009 Report Share Posted October 24, 2009 this is teaching me something Link to comment Share on other sites More sharing options...
fritosaregood Posted October 24, 2009 Report Share Posted October 24, 2009 no one has mentioned the top plate. isnt that what the coil is repelling from (when it is turned into an electromagnet) seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
Boon Posted October 24, 2009 Report Share Posted October 24, 2009 no one has mentioned the top plate. isnt that what the coil is repelling from (when it is turned into an electromagnet) The top plate, AFAIK, is more for focusing the energy of the motor into the gap. 10.x volts fo' life! Link to comment Share on other sites More sharing options...
Forevrbumpn Posted October 24, 2009 Report Share Posted October 24, 2009 top plate is kind of light a lens, it focuses on the magnetic field, different top plates will achieve different results- narrow, or widen the magnetic field, with a loser, or tighter VC gap, or taller top plate, or shorter top plate, or you can use a top plate with a split design, to created a dual magnetic field, for more coil travel, more linear excursion, without causing distortion, or losing motor strength There is also Under hung design, and over hung design 1 the coil is taller than the top plate the other the top plate is really tall, maybe 1.5" tall, and the coil is really short 1.5" tp vs a 0.75 vc example Power handling is mostly dependent on coil surface area, to dissipate heat, and wire gauge has a little to do with that as well Different wire gauge gets you lesser or higher ohms common wire gauge is about 24/25g on a 2.5" coil, 22-18gauge on a 3" coil, and about 18-17gauge on a 4" coil How many layers a coil has, 2, 4, 6, 8 layers determine other factors, like mH - Le of the coil, which will deal a lot with the efficiency of the coil/cone assembly in the magnetic gap A lot of people are using lesser layers, and much longer winding widths now to produce higher efficiency woofers, to create higher Bl, and lower handling woofers I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy. Link to comment Share on other sites More sharing options...
Bumpindemlowzz Posted December 3, 2009 Author Report Share Posted December 3, 2009 Nice to know thanks guys. Im always up to learn something new. 2010 Silverado 18" DC XL 18 DC 2k XS Power Batts Link to comment Share on other sites More sharing options...
