All Activity
- Today
Bogie83 changed their profile photo
Ak471785 changed their profile photo
- Yesterday
Main question is can the opening of all the ports be even or do I need to have the different ports staggered in length?
Timoteo joined the community
Looking at sound quality only
- Last week
Thanks I will do that when I take the subs out for finishing the box exterior. I am thinking I am going to Bondo all the screw holes, route all the edges and have it sprayed with bedliner. I normally carpet them...but I think for this application I had rather have the bedliner finish. It sounds really good so far. I have not had time to set the amp gains with my oscilloscope nor have I tuned the whole system yet. The box does not require much power to get really loud. Thanks again for all your help!!!
What kind of box is needed for two Kicx GX12s?
Joe X replied to FESMO's topic in Subwoofers / Enclosures
The sub parameters make it ideally suited for sealed, nonetheless it looks like it would work in ported but they offer no Xmax parameter so I can only speculate. -
I came up with a shared port design which is approximately what you intended to do in size and performance. Subs up in trunk cars is not recommended due to heavy trunk lid rattling, if you choose to do the subs up just do the cutouts in the top wall instead. The other thing to comment is that many european vehicles have almost air tight trunks, that would result in reduced performance, if removing your rear seats results in you being able to see the trunk, you are ok but if you see just metal, it can be a problem.
So here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/2", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. NOTE: for increased performance subs and port should be firing rearwards.
Rodenstock joined the community
So I had a flame out on one of my B2 rage subs, decided to go ahead and replace both with Sundown Audio U series 12" dvc 4ohms. These subs are rated at 1750 watts rms a piece. I am going to run them parallel to drop to one ohm. So I need a 3500watts rms @1ohm monoblock. Right now I am running a Taramps smart 3 (not the bass version). I found 3 that look like they fit the bill. Id like to get some opinions on them, because some of the brands I never dealt with, some of the brands have a series I cant find reviews for. If yall dont agree with any of the options, please recommend one for me. Thanks in advance https://www.skaraudio.com/products/rp-3500-1d-car-amplifier https://orioncaraudio.com/products/xtr3500-1dz https://ds18.com/collections/car-audio-amplifiers/products/frp-3-5k-bl?view=sl-517F06B8 https://sundownaudio.com/collections/sia-amps/products/sundown-audio-sia-3500d-smart-3500w-wide-range-car-audio-class-d-amplifier-amp https://www.dcsoundlab.com/20k-1 https://usacousticsca.com/big-ben-classD-amplifier.html
FESMO started following What kind of box is needed for two Kicx GX12s?
Hi all, I bought two Kicx GX12 and I don't know what would be the ideal box for it to play as it should and give maximum bass. I also do not understand how best to connect it, 1 ohm, 2 ohm or even more. I ask your help from you, because I know that here sit very smart people
FESMO joined the community
Just spoke with Orion. Their "support" said without running the amps in bridged mode you can't run a single remote level control. When I asked "If I run the amps in bridged mode can I run each amp independently so that I can use one bass knob and NOT wire the speakers between the two amps?" his answer was "Hahaha...you can TRY!". Awesome. At this point IF I was going to go the multiple 3000.1 route I think my plan would be an inline rca signal attenuator before the two amps, run a bass knob per amp set wide open and then breakout the clipping leds to a custom display in the dash (this was the main reason I wanted one knob....clipping indicator.). Ridiculous that in 2024 this is something not built into the amps.
Need some insight from some of the more experienced members. The scenario: I have two Fi Audio Halycon 15"s (basically the Omegas with a few more tweaks). Based on the limited information they can handle at least 4500 watts. Current amp (still building the system): Orion HCCA 3000.1 dsplx Thoughts: Plan is/was to run the two subs wired at a final 1 ohm load (they are 1 ohm dvc subs). Problem is of course impedance rise. Modelling this in Winisd it will essentially rise to 2+ ohms around the tuning frequency of my enclosure (32 hz) resulting in less than desired power output (amp dynos and clamp videos show around 4800 watts at 1 ohm with a system voltage of 14.4-ish volts which is what I am limited to in my system). That's a bit underpowered for these beasts I think. Question: Thinking of adding a second 3000.1. dsplx and using one per sub. That would allow me to wire each sub to .5 ohms which with impedance rise would present about a 1.2 ohm load to each amplifier resulting in more power PER sub. Not totally sure about this option as I am already space constrained on the amp rack AND I would need a second lithium bank and quite a bit more power runs and blocks. Alternatively: COULD ditch the 3000.1 route and move up to the Orion 12500.1 dsplx. That would fit on the rack, might need to add a second lithium bank still, but same wire runs and blocks would work. Concern is once again impedance rise as with one amp and 2 subs I would still be left with a 1 ohm wiring configuration with rise moving the effective load to 2+ ohms. Also: IF I went the two amp route, how do you control the bass level without having to go with a bass knob per amp? In-line signal attenuator? THOUGHT about strapping the two 3000.1's since that would allow me to use one bass knob, BUT once again I keep coming back to the impedance dilemma and effective output. Help appreciated!
Freudie1 changed their profile photo
deproarise joined the community
Finally got around to making a video of my custom setup for everyone on here. Alpine stereo Two evl12s flat pack box kit Russian Baltic Birchwood, 2k amp silver tinned ofc wire and Taramps 4 ch amp 800w for the highs Just a regular old lead acid battery 2007 Merc. I will try to post the video on here directly if it doesn't work in case I will post this YouTube link to the same video so everyone can view. https://youtu.be/A_-y_UDiLCo?feature=shared PXL_20240420_193249332.TS.mp4
gotcha a its in a 2003 bmw 325i (2)Skar SVR 12" subs, Skar audio RP2000.1
jgi420 changed their profile photo
(d2) or (d4)? Sa-12's
Joe X replied to btrango's topic in Sundown Audio - GREAT Amps/Subs! GREAT Customer Service!
It comes down to the minimum stable impedance your amp support, for a D1 wired in parallel you would need a 0.5 ohm stable amp. -
Resonant Frequency Tahoe 2 door 1997
Joe X replied to Gerson80's topic in SPL - SOUND PRESSURE LEVEL
For RF you can go with a larger net volume than suggested and tuning should be within 30-35Hz, subs up / port back for your type of vehicle, something like in the figure below: -
The port in the middle (shared port) adds displacement because there are two non common walls instead of one of the side port design. Besides you don't say what skar subs or power or vehicle you are running which are also important in deciding a design.
Ok...well I built the box over this past weekend. It was really pretty easy. I can't wait to see how it sounds. All parts were cut out using the table saw, I did have to trim the longer pieces to the correct length with a circular saw and fence...but no biggie. I started by laying out where things were going to go. This helps pre-drill holes and also allows you to double check the port spacing at all points. I started assembly with the interior port walls. Next were the bottom and sides. If you have never used these clamps....just buy them. They are worth every penny!! Here we are almost completely done. Just need to put in the wire and mount the subs and it will be read for a trial run.
aaron_waldrop changed their profile photo
Gerson80 replied to Gerson80's topic in SPL - SOUND PRESSURE LEVEL
So, do you recommend for daily to go ahrad with the specifications on the manual??, mines are for daily use, thanks. -
Most head units clip a bit but you set your amplifier gains so that you get all the output of your system before you reach the volume level at which the head unit clips. While learning to setup your system gains properly (with a DD-1 or a cheap little scope) is what you likely need, it wouldn't hurt to get a modern head unit with a better DAC and higher line level outputs voltage, your really old head unit has only 2 Volt, you can get a 4 volt head unit just by not going for the cheapest bottom of the line head unit and those will still be reasonably inexpensive.
There is a thread for that: Say it should be around 40 Hz but if your box is for music and not burps, you don't want to tune close to resonance, it will likely make your system pretty bad. Your subs are for daily not competition.
