cichlidfort Posted February 21, 2008 Report Posted February 21, 2008 So I just got my Hifonics Brutus 2607d amplifier today. I put in the ground, power, speaker, RCAs and remote wire. I then put the fuse in and I turn the car on. I had the gains on the amp completely down and my settings on my HU were low too. I go check the amp just to make sure it was ok to turn the gains up and the red light was on meaning its in protect mode. I was like wtf so I checked EVERYTHING. I checked the ground, changed out the fuse, checked all the wiring again and even switched out the speaker wire with different ones. My setup is in my signiture. I am running my L7s at 1 ohm. Is there anything I could be possibly missing before I send it back and get a new/fixed one? 2008 Chevy Impala (undercover cop style) Setup in the makings
B Slaps Posted February 21, 2008 Report Posted February 21, 2008 So I just got my Hifonics Brutus 2607d amplifier today. I put in the ground, power, speaker, RCAs and remote wire. I then put the fuse in and I turn the car on. I had the gains on the amp completely down and my settings on my HU were low too. I go check the amp just to make sure it was ok to turn the gains up and the red light was on meaning its in protect mode. I was like wtf so I checked EVERYTHING. I checked the ground, changed out the fuse, checked all the wiring again and even switched out the fuse with a different one. My setup is in my signiture. I am running my L7s at 1 ohm. Is there anything I could be possibly missing before I send it back and get a new/fixed one? 1 ohm each???? where did you buy the amp at??? I Rock 4 Doors 4 More Whores! SMD SUPER SELLER my seller feedback http://www.stevemead...-mama-feedback/ more seller feedback http://www.stevemead...-slaps-yo-mama/
cichlidfort Posted February 21, 2008 Author Report Posted February 21, 2008 1 ohm each???? where did you buy the amp at??? No, the subs are dual 4 ohm wired to 1 ohm. I bought the amplifier from Audiosavings.com I am going to return it if the problem can't be fixed. 2008 Chevy Impala (undercover cop style) Setup in the makings
B Slaps Posted February 21, 2008 Report Posted February 21, 2008 No, the subs are dual 4 ohm wired to 1 ohm. I bought the amplifier from Audiosavings.com I am going to return it if the problem can't be fixed. yea watch out on buying things offline where you buy them and who you buy them from. good luck with that. I Rock 4 Doors 4 More Whores! SMD SUPER SELLER my seller feedback http://www.stevemead...-mama-feedback/ more seller feedback http://www.stevemead...-slaps-yo-mama/
cichlidfort Posted February 21, 2008 Author Report Posted February 21, 2008 I have a warranty for it so its fine. I think it was damaged in the shipping process but I want to be sure its nothing that I am completely missing or forgetting about. 2008 Chevy Impala (undercover cop style) Setup in the makings
Chris Posted February 21, 2008 Report Posted February 21, 2008 Is the amp mounted on the box? 4 15" FI Q D2's in 12 cubes tuned to 32hz 1- T1000.1bd's 3 Maxx 29 deep cycles 4 runs of 1/0 gauge -Big 3 -Trunk sealed off from the cabin Custom 15.8 dual-volt switching MLA module All in a CAR.
AI James Posted February 22, 2008 Report Posted February 22, 2008 even if it is on the box, he hasnt even played it yet. IMO see what it does with no load hooked to it as in no speaker wires. if its still in protect then i would send it back.
ChevyBoy Posted February 22, 2008 Report Posted February 22, 2008 and try it without the rca's hooked up. nismo had/has the same problem with his hifonics amp.
cichlidfort Posted February 22, 2008 Author Report Posted February 22, 2008 even if it is on the box, he hasnt even played it yet. IMO see what it does with no load hooked to it as in no speaker wires. if its still in protect then i would send it back. It was still in no protect without the load. 2008 Chevy Impala (undercover cop style) Setup in the makings
Decaf Posted February 22, 2008 Report Posted February 22, 2008 had the same problem with an old bxi-1200d a few years back and it was because there was only 7v at the remote wire because it was loose behind the headunit it would work every noce in awhile then go into protect could be messed up upon arrival also goodluck
