PRE-SALE ORDERS ARE FINAL - THERE WILL BE NO REFUNDS -- If you are not 100% sure you will be financially stable then don't pre-order. No more exceptions.
These amps are capable of a real 1500+ watts at 12.8 volts. They will out-perform many other 1500 watt rated amps (like the Audiopipe 1500) easily!
ETA is the end of November. As always with a pre-sale there can be delays!
COST ON PRE-SALE :
AUGUST - $250 each
SEPTEMBER - $260 each
OCTOBER - $270 each
NOVEMBER - $280 each
PRICE IS SHIPPED IN CONTINENTAL 48 STATES. CONTACT ME ABOUT AK, HI, and international !!!
The earlier you pre-order the lower the price will be.
REGULAR price will be $350 MAP / $549 MSRP when in stock!
PAYPAL me at [email protected] to take advantage of the pre-sale offer.
Pre-sale will be closed on November 15th !
Externally it will look just like the old model SAE-1200D :
Posted Image
Posted Image
Posted Image
Specs are also rated the same :
SPECIFICATIONS:
* 1200 x 1 watts @ 1 ohm
* 600 x 1 watts @ 2 ohms
* 300 x 1 watts @ 4 ohms
* 0.153v - 5.6v adjustable input sensitivity
* 15 Hz - 250 Hz Frequency Response
* > 90 dB S/N Ratio
* 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
* 50 Hz - 250 Hz adjustable 12dB Low-Pass Crossover
* 15 Hz - 50 Hz adjustable 12dB Subsonic Filter
* 0 or 180 degree adjustable phase switch
* 0 - 12 dB adjustable bass boost with 60 Hz center frequency
* Wired Remote Control unit included
* 5x 30 Amp Internal Fuses
* 17" L x 10.6" W x 2.2" H
BUT the board is ALL NEW in design :
Posted Image
Updates :
1) Double sided PCB board (v.1 was single sided)
2) More primary input caps
3) Large brass bars for power supply current
4) Revised layout
5) Superior Soldering and assembly quality
TESTING vs. similar board to Audiopipe 1500 / 1800 :
http://www.soundsolutionsaudio.com/forum/i...mp;#entry546813
Edited by sundownz
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
  • 4 weeks later...
So what will this amp put out at 14.6
PPI dbl din
DC Level 3
1.77cubes net tuned to 33htz.
DC audio 2.0k
currently i have two lvl 4 15's with a J.L. audio 1000/1 on each what would the real time power gain be if i were to swap out amplifiers ?
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
Damn I have 3 jl 1000's I wish I could sell and then buy 3 of these
2005 Lariat F-150
On 30 inch DUBS
6 Crossfire XS-V2 18's
2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4
12 - 6.5 Crescendo mids and 4 Crescendo supertweets
SMD 340 alt, Mechman 270 alt
7 NSB 170 batterys
This topic is now closed to further replies.
