AQ2200 Users!
protocaster69
I should have roughly 200 Amps and prolly 3 batterys... I guess i'll try it... If it don't work I'll order another sub and run em at 1 ohm :) hahaha
I thought you would be broke from just the one sub and amp, and all the wood and stuff.
Don't run it at 0.5 ohm...I swear everyone seems to have a huge boner for low ohms these days, the amp puts out over 2k watts at 1 ohm and is stable there, run it there, if you want to have more power save more money and buy a bigger amp.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Do 2 ohm daily .5 for burp nothing wrong with what you already got if you do that. If you are wanting more power then suck it up and step up in amp size. Lol or just get the copper dual 2.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Well the sub i'm going to run off this 2200w rms amp is rated at 1000w rms and people run 2 2200w amps per sub... So how is that different than running and amp below the ohm load its rated to be "stable"?
ok, just get a 1200d then, or aluminum coils.
but what running 2 amps to one sub have anything to do with running below 1 ohm?
Plan and simple you drop that amp below 10 volts it is done. So dont believe what everyone is trying to help you with and go try it out if you can keep voltage up then great but it only takes one time to screw up and then done and send back to aq.
Evo X build log
2200w is quite a bit of power @1ohm and if you can do well on making an enclosure you'll be very well served with that for a while.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I'm not disagreeing with what they are sayin... I'm just asking a simple question... If people often way over power the rating of the HDC3 subs with 2 aq2200s and i've even heard 2 aq3500s... hence pushing way past what they should handle... why would pushing what the amp can supposedly do be bad? I realize that its not recomended by the manufacture... But once again... Neither is putting 7000w on the 1000w rms HDC3 sub...
I'm not trying to disagree... I'm just wondering what the difference is?
The difference is they're putting clean unclipped power to them and if you try over powering them by running @.5ohm and clipped you'll be one unhappy customer.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
your comparing 2 different things...
overpowering a sub has nothing to do with running an amp at .5,
  • Who's Online   0 Members, 0 Anonymous, 922 Guests (See full list)
