How would this work?
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
My question is how does the sub on the right get power? I know this is a dumb question.
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
I'm trying to figure how I should come out my box. I'm runnig 4 dual 1ohm.. I want a 2ohm load but I want at least 4 runs of 8ga.. So I was gonna wire them like above then parallel the other set. To give me a 2ohm load. But how does the set on the right get power
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Follow the + terminal on the top. The power goes to the right through the coil of the 1st sub, on to the 1st coil of the 2nd sub, to the 2nd coil of the 2nd sub, and lastly to the 2nd coil on the 1st sub before it comes full circle to the - terminal.
what that picture doesn't show is the + and - are actually connected. A voice coil is a single circuit, the + terminal ends at the - terminal of the SAME voice coil.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
So if I wire them up exactly then they will give me a 4ohm load?
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Hang on you say you are running 4 Dual 1 ohm subs but you posted a pic of a wiring diagram for 2 dual 1s?
