battery isolator for dual batteies?
do you have to use one of these to run 2 batteries? i will have 2 red tops under my hood and have seen that everyone uses a battery isolator. i dont see why though if you want to USE both. but they say its so the batteries dont drain each other or something.
if your gonna play you music for long periods of time with vehicle off then YES
if yours for the most part play it with vehicle on the NO
IMO id stay away from them, more unwanted resistance :pardon:
no only time i play with it off is for like one song, maybe.. but would it be good to have one just in case? i dont have that much power anyway. about 500watt rms.
no other opinions on this?
I'd stay away from them. They are nice if you like to bump with your car off and you have less than 1000 watts, but they will reduce the life of your batteries if you keep draining one completely and they will bottleneck your charging power into that battery, and the cheaper ones have a shorter lifespan. Just don't get one and leave your car idle if you want to bump while parked, problem solved.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
ok cool. thanks
Nathan from XS POWER recommended that you do not use them, they dont really do any good unless you want one battery fully charged for when you start, but who cares, if you have 2 or 3 semi charged car audio battires, it will start just fine
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
  • Who's Online   0 Members, 0 Anonymous, 1360 Guests (See full list)
