enclosure for 4 18' FI BTL's
Steve your videos convinced me to contact FI and order some of those BTL's but i need the build specs for that box you had yours in. Please help me out. I have a suburban so im sure it will fit
just cause it works for him doesnt mean its going to work for you
R.I.P!
(Nov-29-2009)
92 explorer
current build
ditto. does this mean your also going to get his exact electrical setup? Amp? number of runs?
I doubt it personally since you have the space use it. make the box more efficent and put less of a strain on your electrical by using so much power. you do realize your going to need around 7-10k of power correct? and the electrical to back it up? your looking at around 1.5k in just amps i'd say. Then 1/2/3 alts(i'd do 2 minimum) and then the big battery bank your going to need.
Johns.jpgSuburban Coming Soon
use fis specs hes said multiple times he should have had more airspace in it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
this is my first attempt at putting a real system together and could use any help you guys have to offer. first of all i know i need more alt power i am a welder by trade and if anyone out there has a picture of dual alt setup on a 93 suburban i could fab one myself(i hope). but i still have no idea how to wire them. im only on fabricating my pillars now 2-4" and 2 tweets in each one. then im moving on to door panels while i wait on enough money to get the amps
Like stated above, lots of power and big electrical. Box built to specs,4 fi btl 18s need a minimum of 20CUFT (almost 100% positive) Makin your own alt bracket isn't that hard, I'm in the process of finishin mine up.
Teamflexissueslong.jpg1995 Sonoma with camper shellJVC KD-R900(12) Incriminator Audio Lethal Injection 15s
Crescendo BC5500 ( sent to me not 18v capable)(7) XS Power d1600(2) 350amp Mike Singer AltsStripper Pole FTW
Member Build Under ConstructionYoutube Videos
  • Who's Online   0 Members, 0 Anonymous, 472 Guests (See full list)
