Soundstream SPLX BREAKING AGAIN
langsdon2
whats with all the gain stuff? its cleary a mechanical fault with the sub, not the amp. Clipped signal would have cooked the coil, not launched a spider spacer or retention ring, whichever one that is. Send the subs back and dont buy that make/model anymore apparently.
You are overlooking something important and only looking at the main issue. What would the point be in getting the equipment replaced only to then ruin it by such a simple oversight.
I'm guessing that you didn't use a scope to set your gains so just because the gain is "set to half way" doesn't mean that you aren't clipping the subs.
clipping wont caused the spiders to delaminate like that...
either your playing WAYYYY below tuning and reaching the mechanical limits of the woofer or theres bad glue joints.
edit: i just seen this was a two page topic and its been handled already.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
can you swap these out for a different brand at the shop. plastic has no business being on a woofer especially in that area.
my cerwin vega v maxes had a 1 inch cardboard/resin spider spacer.. that didnt have issues.. i think this is a glue joint issue.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
X2 alot of companies use plastic spider retaining rings. Some are Audio Que, American Bass, the old RD SHW.mI dont recall any of them having any issues with the rings breaking
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
This is what I was thinking, when I read the first post, then I scroll down and see your clipping your amp, what do you expect.
Just cause he has his gains way half, and he didn't set it with a scope still doesn't mean the amp is clipping. You all are assuming it is.
Still a 1250rms sub, should take 1300watts clipped, but that isn't his problem.
But, since he had more than one break like this, it could possible be the install. Not correctly setting up the subsonic filter, and playing below tuning. But still, a quality woofer shouldn't have this happen. Quality control should of tested everything way past its limits to make sure nothing like this happens with users.
Goodluck. I've always heard SS subs wasn't the best quality, not saying all are like this but still. Its these little things that says a lot about a company.
Once again, the gain is not the issue here. Someone who is normally harping on people for logic and common sense I'm surprised this has escaped you.
The issue is setting gains with DMM and thinking that because its only turned halfway up the amp isn't putting out its full rms. The logic is seriously flawed and WILL lead to issues in the future. And then with expecting the manufacturer to cover it, they could easily use user error as an excuse to not replace the equipment. The issue was the gains were not set correctly, and thinking that because the gain was only turned halfway it was ok. This is not correct.
I agree, but I still don't think this is why the sub had a problem.
He's not asking them to fix burnt coils, usually this is a good sign of clipping.
broken spider spacers are a good sign of clippin? i dont think so.
some stuff you say is smart.. some other things not so much
1250 watt sub taking 1300 clipped watts? wtf is that shit? :popcorn:
you can kill a 5k rms sub with 1000 watts of clipping..
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
Rofl, a 1000rms clipped will not blow a 5000rms sub.
And yes, a respectfully a good 1250rms sub should be able to take 1300rms clipped. For how long? Who knows.. But still, it shouldn't blow up in 10 seconds, or shouldn't. If it does, it should not be rated at 1250.
I'll give you a example, I have a Sony amp, ~500rms. And a 12in Fi Q.
That amp will not blow that sub. Period. Won't do it. EVER. I've ran it wide open, with bass boost wide open, for 5+ mins playing 35hz sinewaves. Sub wasn't even warm.
Unless YOU have blown a 5000rms sub with 1000rms, don't say you can.
If 1000rms can cause damage to a "rated" 5000rms, it shouldn't be rated nowhere near that.
  • Who's Online   0 Members, 0 Anonymous, 14127 Guests (See full list)
