heckvr4 Posted February 15, 2011 Report Posted February 15, 2011 4th order didnt work with my btl's . 6th order suits them better'ish... yeah i agree with RAY' . go big... i just got done with my build and i want to go bigger already.. lol... 05 f150 4 18'' DC lvl6 2 DC AUDIO 9.0ks 161.3 @ 44HZ build log here96 tahoe http://www.stevemeadedesigns.com/board/topic/160522-8-18xls2-dc-100k4th-order/page-9
Scrapmanson Posted February 15, 2011 Author Report Posted February 15, 2011 I THINK I'll be ok with 2 12's as I'm moving from an L7 8"lol! My wife won't let me take up to much bed space so I think that's as big as I can go being it's our only vehicle, and I've put so much $$$ into the other things I've done to it, I've reached my limit:(
Scrapmanson Posted February 16, 2011 Author Report Posted February 16, 2011 Jacob recommended 4.1 cu does that sound right for my situation?
Ray Posted February 17, 2011 Report Posted February 17, 2011 id like 4.8 after better. with 80sq in 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Scrapmanson Posted February 17, 2011 Author Report Posted February 17, 2011 Damn ray that's huge?!?! Here's another opinion.....Do a 4th order mad easy and it will pound. All you need is a 6.5x9.5 hole. Do .875 per sub seald and 2ft3 center chamber with a 40 sq in vent 11 inch long
fritosaregood Posted February 17, 2011 Report Posted February 17, 2011 do not run the SAE 1200d at half ohm. seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
Scrapmanson Posted February 17, 2011 Author Report Posted February 17, 2011 Its the sax 1200d...Why not at .5?
JMZNeal Posted February 17, 2011 Report Posted February 17, 2011 Mine is cut just big enough for the speakers and port to sit in the hole. I used accordion style boot that i used to connect the holes together. it hits hard as f*** 2T1 12's 1ohm on a T10001.1. To me it's the easiest way and looks the best. I've seen the bandpass boxes and bet they hit hard as fuck when done right... But a box for two twelves could be up to 54" wideish in a little truck 15.5 high and deep enough to get your tuning right before the fenders or you notch it alittle if you have to. then you make a cover or something... rhino line the bitch and water proof it and use the rest of the bed how wide is your bed and how deep is it from the bottom of the bed rail? that's a rough pic of the inside of my cab. i used a piece of square tubing to re-enforce the brace that was cut across the top. it left me with enough space to corner a set of 8's on the sides of it idk if that's what your looking for but it's my best solution to keep the Mrs. happy and give you heavy ass bass. it's a trade off between small hole... no bed or big hole and still have 2/3 of your bed. JVC AVX-44 and 360.2 Subs: 2 RF T1 12s 1ohm mono off a RF T1500bdcp 80hz \/ in a 2.3cube 45hz slot port Mids: 2 O2 8's off a Punch 550.2 behind seat, 2 Image Cxs 6.5's and 2 ID XS 6x9s 80-3khz in doors on a T600.2 Highs: 2 ID CD.1 MH HLCD 8ohm off a RF 400.4 3khz /\
fritosaregood Posted February 17, 2011 Report Posted February 17, 2011 Its the sax 1200d...Why not at .5? oh, ok. Not sure about that amp at .5 ohm. If it was me i would stick to 1 ohm though. just to make it easier on the electrical seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
Scrapmanson Posted February 17, 2011 Author Report Posted February 17, 2011 Mine is cut just big enough for the speakers and port to sit in the hole. I used accordion style boot that i used to connect the holes together. it hits hard as f*** 2T1 12's 1ohm on a T10001.1. To me it's the easiest way and looks the best. I've seen the bandpass boxes and bet they hit hard as fuck when done right... But a box for two twelves could be up to 54" wideish in a little truck 15.5 high and deep enough to get your tuning right before the fenders or you notch it alittle if you have to. then you make a cover or something... rhino line the bitch and water proof it and use the rest of the bed how wide is your bed and how deep is it from the bottom of the bed rail? that's a rough pic of the inside of my cab. i used a piece of square tubing to re-enforce the brace that was cut across the top. it left me with enough space to corner a set of 8's on the sides of it idk if that's what your looking for but it's my best solution to keep the Mrs. happy and give you heavy ass bass. it's a trade off between small hole... no bed or big hole and still have 2/3 of your bed. My truck is a full size so I have 63 1/2 across 19" height and 30" to wheel base...
