ok guys whats the pros and cons of using pvc pipe for ports instead of getting aero ports from parts express?
im going to need 6 inch x13inch ones
I SCAM PEOPLE OUT OF MONEY... AVOID ME LIKE I AM AN AIDS INFECTED RETARD...
its cheaper.
pros
its not flared
youll need to flare it and by the time you are done fucking up the pieces of pipe you could have bought the aeros
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yeah the flares are to help with the movement of air and how smooth it enters and exits the box. You could jus use pvc, it might not sound the best. You could flare it, but you need the proper tools to flare, and that'll take sometime. But if you are down for manual labor beyond just installing a premade flared port, go for it.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
Theres tutorials on how to flare pvc
Had an estimate of 6400 for an alpine/clarion setup dealer said it "should" hit around 160db with the custom boxes he was going to make for me..doubtful with so much area to move but, budget is way below that :( any ideas on cheaper brands for that kind of Spl setup? really didnt want to try any Boss or soundstorm, thinking Quantum figure around $150 per speaker "$1800 total" and $1700 to power it, first actual big setup for the van.
New MEMPHIS CAR AUDIO build
4 15s Memphis C3
2 xs power D3100
1 xs power d3400
custom fiberglass door pannel
and lots more
My Build
i just dont know if its worth getting the ports from parts express instead of using pvc
is there much if any audible difference
Edited by zachfowler222
If you are using something 6" or smaller, might as well buy the Precision Port in my opinion. Unless you are good at it, I find it worth the extra bucks for one made "flawless."
If you want to use an 8" or 10" or etc, you gotta make your own out of pvc.
If you make your own out of pvc to look exactly like the precision's, they will sound the same.
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
what about if i dont flare the pvc so basically just a pipe....... is it an difference by ear or will i just really tell on the meter?
i wrecken youll acquire some port noise, someone correct me if im wrong.
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
