no im saying change the RCAs on your radio from sub to like your fronts or rears, you might have a blown sub channel on your head unit
Team_DC-Derrick's Youtube
Team DC Audio
are your RCA's Directional??
Set the DMM to AC voltage put it on the speaker terminals of the amp, turn the gain up some and see if you get a reading...if not, either your outputs are cooked or you must move on and try to diagnose a problem elsewhere
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
Set the DMM to AC Voltage, then check the outputs on your Headunit. If you don't have any voltage on your headunit, that is your problem.
If you have voltage on your headunit, connect the RCA's to your headunit but not your amp. Check AC Voltage on the unconnected end of the RCA's. If you don't have voltage, you have bad RCA's.
If you have voltage on your rca's, connect the RCA'a to your amp and check ac voltage on the outputs of the amp. If you don't have voltage, you have a broke amp.
If you have voltage on your amps outputs, check your speakers.
97 Maxima SE
Bunch of shit going in, check out the build
did you adjust the gain?
Hey I put it on ac and check my RCA on my hu and read 0 I put both of them in the hole for the RCA and rub them on the RCA on hu and still 0 so Its the hu. Before I had a Bose hu and got the Loc called the mx-4 for my RCA and it still hook up but no power going to it tho.
is the sub output turned completely off?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
That's why i said put your rca on your front or rear out put from the radio... To try that
Team DC Audio
  • Who's Online   0 Members, 0 Anonymous, 793 Guests (See full list)
