so far i've only got 1 run of kicker hyperflex for pos, and one run of GSI 100%OFC for my neg run
i was considering either:
taking my neg run and changing it to a positive run
OR
buying 16-17ft of knu KCA cable and add a second run of positive and keeping the negative run i have currently
reason i was considering just changing my current neg run from front to back cause i never saw an increase with it or a decrease without it..
gonna be running a sax100.4 and a saz3500d for power, i was going to fuse each positive run (if i did 2) with 250a fuses, currently my single main run has a 300a fuse
and i was also going to run 250a fuses in both power wires right before the second batt in the back (xs d2700)
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
I have 2 positive runs 1 negative run from the front to the back. then I also grounded a run to the chassis in the back to the battery. works fine for me /shrug
2004 Volkswagen GLI
1 10" Skar VVX
^^^ Looking for an amp to run it, Pm me if you have one ^^^
If you buy the KCA then I think you should use the GSI as a positive run. OFC > CCA
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
well either way at that point both power runs will be fused with 250a fuses
which i most likely won't see a decrease, i used to use CCA and tbh when i upgraded i never saw any type of voltage increase in any aspect
Team Sundown Audio
Anyone ever heard of/use bullz audio 1/0? 100% OFC
Team Sundown Audio
It's not always about a voltage increase, sometimes it's about being safe. If too much current flows throughout your wire it could melt the "jacket" and you car could look like the 4th of July.
But with 250a I think you should be alright. Not 100% sure cuz I don't know what the KCA's amperage rating is
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
KCA is rated 260a over a 20ft run
Team Sundown Audio
That bullz audio wire is really cheap. Its like the size of 4 gauge
1990 Nissan 300zx Twin Turbo - Summer Ride(No system yet, lookin to get it up to 450-500 horse first!)2006 Chevy Malibu - Daily DriverDC Level 5 15", 2 APSM-1500's, 3.88 cu. ft. tuned to 32hz1992 Honda Prelude - SOLD2 18" TC 3hp Woofers on a Crescendo BC3500.1d, 12.7 cu. ft. tuned to 35hz7r.png
I would personally think that the ground should be stronger than the power, but that's just me. 2 runs of positive can bring the current back, but its needs to return somehow. And if you have 1 neg, idk how efficient that will be. But I may be wrong.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
  • Who's Online   1 Member, 0 Anonymous, 780 Guests (See full list)
