Ford302Redneck Posted February 20, 2011 Author Report Posted February 20, 2011 Who said I had to have a loud substage all the time? Why can't I have good SQ at reasonable levels, then still have loudness when I want it? Sure the SQ will suffer when I want it to be loud, I'm not as worried about having perfect SQ when that happens. Your missing the point. I want both. Not at the same time. I stated that in the first post, just didn't spell it out. I figured people would have common sense. should be "you're" you can have whatever you want. idk why you feel you have to announce it to everyone. seems like a "i want attention post" Is that the only thing you can argue in my post? I'm sure if I combed through your post I could find a error. And so now, I can't make a topic on a public forum and discuss it? So everybody that posts threads are attention whores? Yeah, if you say. no not everyone. just you. you see you made a point to try and tell everyone what SQL should be considered. i just made a counter point that i do not agree with your idea. it is called a discussion, get it? like i said earlier call it whatever the hell you want but do not try to make it a standard. it's pointless I said in my first post nobody had to agree. I was thinking and figured I would share. I'm not asking everybody to use SQL as what I described it. I'm just plainly saying, SQL can make sense. That's one reason why I put SQ(L). Its separate. You can't have both at the same time, but it is possible to have both. That's my point. SQ(L) can exist. And if somebody uses the term SQL and then briefly describe what they mean by that. It is ok to use the term, if they understand what they are saying.
MrSkippyJ Posted February 20, 2011 Report Posted February 20, 2011 It also really depends on what you are going to do with your system, if you are competing in SQ then no, your vehicle won't be able to play loud. If you don't compete, you can set it up to be loud and somewhat "SQ" sounding also. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
IH8PunkRok Posted February 20, 2011 Report Posted February 20, 2011 I said in my first post nobody had to agree. I was thinking and figured I would share. I'm not asking everybody to use SQL as what I described it. I'm just plainly saying, SQL can make sense. That's one reason why I put SQ(L). Its separate. You can't have both at the same time, but it is possible to have both. That's my point. SQ(L) can exist. And if somebody uses the term SQL and then briefly describe what they mean by that. It is ok to use the term, if they understand what they are saying. you are still trying to argue how the term can be universally used but whatever. use your terminology. just do not get angry when someone says there is no such thing as SQL or in your case SQ(L) -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Ford302Redneck Posted February 20, 2011 Author Report Posted February 20, 2011 It also really depends on what you are going to do with your system, if you are competing in SQ then no, your vehicle won't be able to play loud. If you don't compete, you can set it up to be loud and somewhat "SQ" sounding also. I'm not going to compete in a SQ class. And I'm not asking for a 100% flat response. (As my tastes like something else). But it will be able to be EQed to be close to flat when I option to. I do want the proper frontstage imaging. Mostly your imaging goes out the window with loudness.
Alex K Posted February 20, 2011 Report Posted February 20, 2011 I thought sql was sound quality lvl.. Just as spl is sound pressure level.. Or SQL Sound QuaLity... w/e lol 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
Ford302Redneck Posted February 20, 2011 Author Report Posted February 20, 2011 I said in my first post nobody had to agree. I was thinking and figured I would share. I'm not asking everybody to use SQL as what I described it. I'm just plainly saying, SQL can make sense. That's one reason why I put SQ(L). Its separate. You can't have both at the same time, but it is possible to have both. That's my point. SQ(L) can exist. And if somebody uses the term SQL and then briefly describe what they mean by that. It is ok to use the term, if they understand what they are saying. you are still trying to argue how the term can be universally used but whatever. use your terminology. just do not get angry when someone says there is no such thing as SQL or in your case SQ(L) Honestly SQ shouldn't be used either, as most people have no idea what it actually is. People use it as it doesn't distort or have a poor response as SQ. Which is no where near SQ.
MrSkippyJ Posted February 20, 2011 Report Posted February 20, 2011 It also really depends on what you are going to do with your system, if you are competing in SQ then no, your vehicle won't be able to play loud. If you don't compete, you can set it up to be loud and somewhat "SQ" sounding also. I'm not going to compete in a SQ class. And I'm not asking for a 100% flat response. (As my tastes like something else). But it will be able to be EQed to be close to flat when I option to. I do want the proper frontstage imaging. Mostly your imaging goes out the window with loudness. true imagine goes real fast. however so does the frequency response, the extra coloration speakers add to the sound when playing loud, all the extra system noise from high power amps. There is lots of talk about imaging and EQ, but if that is all there was to a SQ install then lots of people would have loud and SQ at the same time. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
korey_hofer Posted February 20, 2011 Report Posted February 20, 2011 sq guys gonna face palm to this previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Ford302Redneck Posted February 20, 2011 Author Report Posted February 20, 2011 I thought sql was sound quality lvl.. Just as spl is sound pressure level.. Or SQL Sound QuaLity... w/e lol It has been used as Sound Quality level, but I don't see where that makes any sense. And why would SQL = Sound QuaLity, when SQ= Sound Quality. No need to add a letter to say the same thing.
korey_hofer Posted February 20, 2011 Report Posted February 20, 2011 sql is a term made because people think sq systems can't be loud because they don't build pressure like spl systems do. that is just s myth though, you can get plenty of those cars loud enough to be uncomfortable previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
